Thread: Engine Swap Help
Results 1 to 3 of 3
  1. #1 Engine Swap Help
    Aug 2012
    United States
    Have 2 Grand Prix's, 2000 GT and 2002 GT, both are K vins. The motor in the 00 went bye-bye. The motor in the 02 is good but was involved in an accident so the body is crap. We pulled the bad motor from the 00 and went to start pulling the one in the 02 but noticed right away that the injectors and the connector on them are totally different than the 00. The 00 looks like the injector has 4 holes while the 02 looks like 2. Can I just pull the fuel rails and injectors from the 00 and put that on the 02, or do the intakes have to the be changed also? Or, is this even possible at all to swap? Thanks for any help!
  2. #2 Re: Engine Swap Help
    It's still a direct swap, just put the fuel rail and injectors from the 2000 on the 2002 motor and call it good.
  3. #3 Re: Engine Swap Help
    Aug 2012
    United States
    Thank you Sir! Just hesitated when I saw that.
  1. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  4. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
