Thread: car just killed on me while driving
Page 1 of 8 123 ... LastLast
Results 1 to 20 of 142
  1. #1 car just killed on me while driving
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    I was just cruising down the street and my car killed on me and the fuel light and battery light came on what could that mean
  2. #2 Re: car just killed on me while driving
    GT Level Member Xorbex's Avatar
    Canada
    Alternator?
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  3. #3 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    Yea I think that's what it is I have a 220 amp high output alternator but I have heavy sound and alot of other accessories in my car
  4. #4 Re: car just killed on me while driving
    Canada
    check it with a multimeter
  5. #5 Re: car just killed on me while driving
    St. Louis
    Did the tach drop to zero before it died? If so probably the crankshaft position sensor. And no, it won't throw a code usually.
  6. #6 Re: car just killed on me while driving
    First thought is crank sensor.
  7. #7 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    Yea the tach did drop
  8. #8 Re: car just killed on me while driving
    thats typical crank sensor failing.
  9. #9 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    Is that an easy fix
  10. #10 Re: car just killed on me while driving
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Hardest part will be breaking the crank bolt loose (i use a good 1/2" breaker bar w/cheater pipe, and vice grips on the flexplate), also need a harmonic balancer puller from autozone. Search to find the details, but its not too hard, maybe 1.5 hour job.
  11. #11 Re: car just killed on me while driving
    Or just do the ol starter trick to crack the HB bolt loose.
    04 Comp G.
  12. #12 Re: car just killed on me while driving
    St. Louis
    FYI, the balancer puller you get will not have the correct bolts for these HB's. You need to buy the correct ones. I know the specs are around here for them.
    And for the love of god, please be sure to line up the keyway on the HB with the key on the crankshaft BEFORE you hammer the crank bolt back in or you WILL have issues.
  13. #13 Re: car just killed on me while driving
    Sep 2014
    New Orleans
  14. #14 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    The harmonic balancer not coming off
  15. #15 Re: car just killed on me while driving
    St. Louis
    Do you have the little cone shaped thing at the end of the remover? If so, take it off. It's probably not sitting on the end of the crankshaft like it needs to be.
  16. #16 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    Ok wats the easiest way to get it out because I think it's stuck in inside
  17. #17 Re: car just killed on me while driving
    St. Louis
    What is stuck? The cone shaped piece? Grab some pliers and see if you can get it that way. Or try smacking one edge of it and see if it pops loose out of the balancer.
  18. #18 Re: car just killed on me while driving
    Sep 2014
    New Orleans
  19. #19 Re: car just killed on me while driving
    Sep 2014
    New Orleans
  20. #20 Re: car just killed on me while driving
    Sep 2014
    New Orleans
    Finally got it out now wat else to do
  1. Got killed.....well could have
    By 98L36 in forum Track Sessions and Kills
    Last Post: 09-14-2011, 12:00 AM
  2. 2 stangs, killed and got killed
    By Boosted02GTP in forum Track Sessions and Kills
    Last Post: 10-30-2010, 08:28 PM
  3. killed
    By Standby in forum Track Sessions and Kills
    Last Post: 07-16-2009, 10:45 AM
  4. I got killed....
    By SlowM90 in forum Track Sessions and Kills
    Last Post: 04-19-2009, 08:20 PM
  5. I got killed
    By TDCRacing in forum Track Sessions and Kills
    Last Post: 08-02-2008, 04:54 PM
