Thread: Random Stalling only when hot
Results 1 to 8 of 8
  1. #1 Random Stalling only when hot
    Toronto
    2001 Grand prix gt. Did upper and lower gaskets last Xmas. Ran fine then 2 months ago has started stalling and hesitating. Runs fine when cold only happens once it gets warm. Where do I start looking?
    Also is there a way to get the check engine codes from the ecu without a scanner?
    Sent from my XT910 using Tapatalk 2
  2. #2 Re: Random Stalling only when hot
    St. Louis
    Pull those codes first.
    No, a scanner is the only way to retreive the codes. Hit up a local parts store as they should be able to scan it for free. Post the codes here and we can offer better suggestions on what to look at.
  3. #3 Re: Random Stalling only when hot
    GT Level Member Beelzeboul's Avatar
    Racine
    usually rough idle means you have a vac leak when you have them scan it for the codes ask if they could look at Your LTFTs (Long term Fuel Trims) if its pegged at 16.4 you got a vac leak to find
    I'm sorry officer I didnt know I couldn't do that
  4. #4 Re: Random Stalling only when hot
    Nov 2011
    indiana
    what about ignition control module... just an idea since only does when warm...
    Toronto
    Quote Originally Posted by Beelzeboul View Post
    No rough idle (as a general rule that is) . It will hesitate and stall if I give it too much gas, it then run fine for a bit then anywhere from 1 to 30 min later do it again. Does it at idle or under load. Regardless thanks for the suggestions. I will get the codes pulled this week and post them up thanks
  6. #6 Re: Random Stalling only when hot
    Donating Users
    Mar 2012
    Toms Riviera
    Curious, Did you ever find the problem, it sounds incredibly similar to what my 01 gtp just started doing-occaisional roving idle-from surging to 1500 and then almost stalling, bucking at light throttle-only occaisional as well, and No Codes. It sounds like a vaccuum leak to me, but He11 if I can find it!-Oh, and all only when Warm-Runs like a scalded cat when cool/cold. Not the cat, not the rear O2 (deleted to confirm). So far I've swapped out all the ignition parts (parts car, 00 gtp) for testing and no change .........Thanks for looking, Mike
  7. #7 Re: Random Stalling only when hot
    Feb 2013
    37.295091, -121.930053
    i would look at the fuel pressure. if your pressure is low it can cause it to run poorly. i had my fuel pump go out on mine its not that hard to change
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  8. #8 Re: Random Stalling only when hot
    Toronto
    I replaced the maf sensor with one from the wreckers and it was fine after that.
  1. Random Stalling PLEASE HELP IF YOU CAN!!
    By Bre in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-08-2012, 04:01 PM
  2. Random Stalling
    By 02Grandgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-25-2010, 01:17 AM
  3. Random RPM stumbling/stalling
    By Ransom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 01:02 PM
  4. Random Stalling Problems - PLEASE HELP!!!
    By teamramrodd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-14-2009, 03:31 PM
  5. random stalling
    By krippled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2008, 08:28 PM
