Thread: CSC Build
Results 41 to 60 of 64
  1. #1 Re: CSC Build
    Jan 1970
    Maquoketa, Iowa
    The shorter dogbones are just going to pull the downpipe up closer to the firewall so I don't know what you're gaining there anyway.
  2. #2 Re: CSC Build
    Apr 2011
    Tally, FL
    Quote Originally Posted by FoSHO99 View Post
    yep i tried the minivan shorter dogbones and the back of the engine was raising up pushing the rear header and downpipe back into the area i used the prybar on. i think i gunna try the poly trans mount. i heard it stops more movement of the engine than the motor mount plus its cheaper. If not ill just take a battleaxe to the firewall.
  3. #3 Re: CSC Build
    Apr 2009
    Fort Worth TX
    I see what you're saying.
    Makes sense.
  4. #4 Re: CSC Build
    Apr 2011
    Tally, FL
    Well its in an running
  5. #5 Re: CSC Build
  6. #6 Re: CSC Build
    Apr 2011
    Tally, FL
    pretty sure that a picture
    it sounds like a plane when u start to get on it
    lots of misfires and kr from poor tune
    videos whenever i feel like it
    Yea your picture doesn't work
    04 Comp G.
  8. #8 Re: CSC Build
    Bettendorf, IA
    How much boost you running?
  9. #9 Re: CSC Build
    Apr 2011
    Tally, FL
    running a 3.8 pully right now so maybe around 9-12 psi, haven't installed my gauges yet
  10. #10 Re: CSC Build
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Need to see more than just this single picture.
    In for MOAR.
  11. #11 Re: CSC Build
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  12. #12 Re: CSC Build
    lapeer michigan
    so is there any csc kits floating around still for sale?
  13. #13 Re: CSC Build
    Quote Originally Posted by whitcomb View Post
    call ZZP. i would be surprised if they didnt have a kit collecting dust on their shelves or at least a line on one.
  14. #14 Re: CSC Build
    Apr 2011
    Tally, FL
    not that i know of
    Update: Replaced radiator since the shroud damaged the fins, installed new slim fans, Installed Wideband, Boost gauge, still trying figure out out to install and oil pressure gauge since the fitting i have is so close to the oil filter housing. Replaced lq4 maf giving me 11.1 mpg.
    Apr 2011
    Tally, FL
    some pics
    Sent from the jungle……ssshhhh Rambo is nearby
  16. #16 Re: CSC Build
    Apr 2011
    Tally, FL
  17. #17 Re: CSC Build
    Ohio
    Did you get the oil pressure gauge hooked up?
  18. #18 Re: CSC Build
    Apr 2011
    Tally, FL
    no i left my sender at the shop when i was waitint to get the isolator, its on the todo list after the fuel pump install
  19. #19 Re: CSC Build
    Ohio
    do a tee in the middle of the oil feed line before the csc
  20. #20 Re: CSC Build
    Apr 2011
    Tally, FL
    Quote Originally Posted by 99PGPGT View Post
    why
  1. selliott turbo gp
    By selliott in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2020, 08:39 AM
  2. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  3. This build
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2011, 09:19 PM
  4. New build.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 05:44 PM
  5. The Build...?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 11-04-2009, 07:35 PM
