Thread: Help me replace my coolant elbow
Results 1 to 20 of 26
  1. #1 Help me replace my coolant elbow
    May 2013
    United States
    Last night (on prom of all nights..) my coolant elbow blew going from the front of the water pump to the head, i went to advanced autoparts today and bought a replacement kit (aluminum). well it seems like the elbow i am supposed to use wont fit, one end is too large, Below is the EXACT kit i got from advanced, and as you can see, the one on the right has a larger end, im pretty sure that is the one i use to replace the one i busted. i will post a pic below of my busted elbow as well..HOW DO I REPLACE IT if its too big!?
    http://i242.photobucket.com/albums/f...gartxx/077.jpg
    Dorman 47065HP HVAC Heater Hose Connector Aluminum Coolant Elbows in Stock | eBay
  2. #2 Re: Help me replace my coolant elbow
    Grand Rapids, MI
    no that's the right set.
    what year is your car? the bigger end goes into the water pump
  3. #3 Re: Help me replace my coolant elbow
    you have 2 elbows, the lower one uses the one with the fat side and the purple O ring. if you have a 97 or 98 your lower elbow is part of the alt bracket and is made of cast metal. if you have this 97-98 year read that how to so you dont break the timing cover.
    heres the how too. http://www.grandprixforums.net/how-c...ows-49779.html
  4. #4 Re: Help me replace my coolant elbow
    May 2013
    United States
    I have a 2000 Grand Prix gt, bone stock, if these arnt the right elbows, what do the ones I need look like? I can't do much research as I'm at work right now lol
  5. #5 Re: Help me replace my coolant elbow
    they are the right elbows that you bought, you need to take the alternator off, and then the alt bracket off the car, clean the holes real good scrape out any crud in there, all 4 holes, then oil the o rings and re install the bracket with the new elbows.
    read the how to.
  6. #6 Re: Help me replace my coolant elbow
    May 2013
    United States
    Why do I need to take the alt and stuff off if its in front of it?
  7. #7 Re: Help me replace my coolant elbow
    because you have to, thats why lol,, if you notice the new elbow wont go in the holes, thats why you are trying to use the lower elbow, but it wont fit there right, take the alt bracket off and replace them per the how to, its the only way, unless you feel like doing the lim gaskets, then you can just change the upper one, some how im sure you dont want to dump 100 bucks in gaskets when you can remove a few bolts and be done with it.
  8. #8 Re: Help me replace my coolant elbow
    May 2013
    United States
    Ok I will do that when I'm home, since I got two elbows, where does the other one go? This is my first Prix, or even my first v6, and since I don't want the other to bust, I may as well replace it
  9. #9 Re: Help me replace my coolant elbow
    did you not read the how to?
    its also in the alt bracket, it goes into the timing cover. these 2 dumb elbows feed the hoses off the back of the alt bracket that go to the heater core.
  10. #10 Re: Help me replace my coolant elbow
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  11. #11 Re: Help me replace my coolant elbow
    May 2013
    United States
    No I can't read it till I'm home, not enough time right now
  12. #12 Re: Help me replace my coolant elbow
    its all in there, tool list as well. with pics.
  13. #13 Re: Help me replace my coolant elbow
    May 2013
    United States
    Got everything worked out and installed, hopefully I did it right! Seemed to work good, thanks guys!
  14. #14 Re: Help me replace my coolant elbow
    GT Level Member GrandprixGT01's Avatar
    Nov 2011
    Keswick, Ontario
    Just had this happen to me on Friday I feel your pain lol. It happened to me at a bad time too. Coolant pissing everywhere. Popped a little pinhole right through the front one. Anyhow good time to replace them and do a coolant flush.
    2003 GT: Wizzair CAI, Flipped Dog Bones, MagnaFlow Mufflers, SE Exhaust Tips
  15. #15 Re: Help me replace my coolant elbow
    May 2013
    United States
    mine blew apart lmao but yes i replaced them both, great investment so far, many more to go
  16. #16 Re: Help me replace my coolant elbow
    If you guys didn't ignore your engines (kinda like I am at the moment) you wouldn't have "bad timing" issues as often. Back in Scotties day, they lifted the hood much more often and paid attention to what was happening.
    I have a noise. From what little I've paid attention to it.. kinda sounds like an AC compressor clutch. Yeah.. it's only 216K miles
  17. #17 Re: Help me replace my coolant elbow
    Nov 2011
    Keswick, Ontario
    Actually its funny you say that because just that morning I had the hood open and was cleaning the engine a little bit, just wiping everything down really. I was actually checking those elbows and yes they looked a little faded but there was no crack, sign of leak, or anything. 1 hour later I go for a little drive and to get my car wax since it was nice out and the front one fails and there went my whole day.
  18. #18 Re: Help me replace my coolant elbow
    A whole day for something that should be able to be done in under an hour?
  19. #19 Re: Help me replace my coolant elbow
    Nov 2011
    Keswick, Ontario
    [QUOTE=BillBoost37;1045725]A whole day for something that should be able to be done in under an hour?[/QUOTE
    I went out and drove 30 minutes from home. When I parked the car thats when I guess it popped and coolant started pissing everywhere. Had to get a tow. It was really a 5 hour ordeal but I meant it was a whole day where I had plans wasted due to this problem.
  20. #20 Re: Help me replace my coolant elbow
    if you had a 25 piece socket set in your trunk, the tow would have never happened, you can do elbows on the side of the road if need be.
    hope you have AAA or something.
  1. Bad coolant elbow
    By Shoggy24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2013, 06:11 PM
  2. Coolant elbow question
    By sickhix04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2013, 01:09 AM
  3. Coolant Elbow...AGAIN!!!
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2011, 06:32 PM
  4. coolant elbow replace
    By misterman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2010, 08:55 PM
  5. Coolant Elbow(s?) on 98 GTP
    By ASCStinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2009, 03:46 PM
