Thread: CSC Build
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 64
  1. #1 CSC Build
    Apr 2011
    Tally, FL
    So whenever i get my suspension rotors and brake pad done i'm thinking starting my Csc build in something like this order
    phase 1:
    hv stage 2 tb - installed
    poly motor mounts- installed but squeaks when shifting, noticeable increase in vibration
    poly dogbone bushing -
    solid motor mount - installed
    hv3 insert - installed
    headers- installed zzp headers not a great fit, rubbing again firewall cause, can hear random rubbing
    phase 2:
    transgo shift kit
    water pump underdrive pulley-installed
    relocate battery to trunk-
    triple pod- boost, oil pressure, aem wideband
    exhaust- installed 3in dp to 2.5 catback
    phase 3 or 2:
    ported lim- installed
    xp hot cam - 105# springs(for semi daily driving), mod'd retainers and Rollmaster double roller timing chain, valve locks,machines oil pump with gaskets
    Lsx lifters- accquired
    Yella terra 1.6- accquired
    phase 4:
    change fuel pump-
    aeroforce gauge- take out boost gauge
    miscellaneous-
    phase 5:
    pdr or pdr with 2-tone paint job
    re-tint the car- 15 or 20%
    brickyard spoiler with brake light-
    body kit- ???
  2. #2 Re: N/A Csc build
    Apr 2011
    Tally, FL
    Few Csc pics
    few pic of the csc kit
  3. #3 Re: N/A Csc build
    Go used ZZP headers.
    Skip the under drive, cooling is good. You might want to get a larger rad.
    Get new OEM LS7 lifters.
    Yella Terra YT 6669, 1.61 ratio. Not a fan of the HS rockers. Apparently at high lift you'll have less lift with 1.7 RR than stock rockers. Almost suggest the 1.7's based on that. (YT 6649)
    Crow 105's?
    Get your double roller crank gear machined, and possible re-hardened. Or use a new stock setup.
    Good paint will set you back most of your budget.
  4. #4 Re: N/A Csc build
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    some reason i was under the impression couldnt do turbo with headers? guessing thats not true?
  5. #5 Re: N/A Csc build
  6. #6 Re: N/A Csc build
    Quote Originally Posted by Grimsin View Post
    You could custom make some turbo manifolds...other than that...that is just a centrifugal supercharger...still belt driven.
  7. #7 Re: CSC Build
    Apr 2011
    Tally, FL
    installed a ported lim, dorman uim and hv3 insert last week. Before install i was seeing kr of 14-16 at wot now im around 6-8 so it seemed to cut it in half.
    my old lim after 13 years and 67k miles
    heres one of the old gaskets
  8. #8 Re: CSC Build
    Apr 2011
    Tally, FL
    Just need to get my catback so i can install these:
  9. #9 Re: CSC Build
    Topeka, KS
    Yes! I finally get to see someone do a Novi setup! I can't wait to see it completed!
  10. #10 Re: N/A Csc build
    Omaha, NE
    Click this: Centrifugal Supercharger
    This looks like a fun build! MOAR PICS!
  11. #11 Re: CSC Build
    St Thomas Ontario
    Ya I figured that out back in October of 2011 lols. when blue told me.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  12. #12 Re: CSC Build
    I've seen one in person. Neat way to do it.
  13. #13 Re: CSC Build
  14. #14 Re: CSC Build
    Apr 2011
    Tally, FL
    its actually $2350 on paxton website and a rebuild is like $500+ shipping. I figure with the gauges and tuner i got along with it in the deal i figured it really only cost me $1200 granted i need a new cog pulley and some other minor stuff, so i'll say it cost me $1500 and i hope to be 2 secs faster right out the gate, so maybe around 13.6-13.8 quater
  15. #15 Re: CSC Build
    i sure hope this thing see 12's if not 11's.
  16. #16 Re: CSC Build
    Apr 2011
    Tally, FL
    Finally got exhaust installed
    They werent kidding about finding headers that can easily fit into a 5th gen monte
    The back headers are rubbing against the firewall causing random vibrations when driving or using the AC
  17. #17 Re: CSC Build
    St. Louis
    Time to remove that header and "massage" the firewall with a BFH. Maybe introducing a bunch of false KR with it like that. Looks awesome otherwise! Nice job.
  18. #18 Re: CSC Build
    Apr 2011
    Tally, FL
    Quote Originally Posted by FordMan77 View Post
    Whats a BFH? maybe with the shifts but i had 7kr at wot before the headers and still have 7kr after
  19. #19 Re: CSC Build
    Big ****ing Hammer=BFH
    SMGPFC Member #10
  20. #20 Re: CSC Build
    St. Louis
    big fvcking hammer, also known as a Ford wrench. Also, where did you have it tuned at? Were all these mods already on it when it was tuned?
  1. selliott turbo gp
    By selliott in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2020, 08:39 AM
  2. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  3. This build
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2011, 09:19 PM
  4. New build.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 05:44 PM
  5. The Build...?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 11-04-2009, 07:35 PM
