The shorter dogbones are just going to pull the downpipe up closer to the firewall so I don't know what you're gaining there anyway.
yep i tried the minivan shorter dogbones and the back of the engine was raising up pushing the rear header and downpipe back into the area i used the prybar on. i think i gunna try the poly trans mount. i heard it stops more movement of the engine than the motor mount plus its cheaper. If not ill just take a battleaxe to the firewall.
http://img.tapatalk.com/d/12/12/15/6e8yduja.jpg
Well its in an running
pictures, videos, comments on it besides 'it runs'?
pretty sure that a picture
it sounds like a plane when u start to get on it
lots of misfires and kr from poor tune
videos whenever i feel like it
Yea your picture doesn't work
How much boost you running?
Need to see more than just this single picture.
In for MOAR.
running a 3.8 pully right now so maybe around 9-12 psi, haven't installed my gauges yet
so is there any csc kits floating around still for sale?
not that i know of
Update: Replaced radiator since the shroud damaged the fins, installed new slim fans, Installed Wideband, Boost gauge, still trying figure out out to install and oil pressure gauge since the fitting i have is so close to the oil filter housing. Replaced lq4 maf giving me 11.1 mpg.
some pics
http://img.tapatalk.com/d/13/01/08/e2e4yjah.jpghttp://img.tapatalk.com/d/13/01/08/sary9epu.jpg
Sent from the jungle……ssshhhh Rambo is nearby
Did you get the oil pressure gauge hooked up?
no i left my sender at the shop when i was waitint to get the isolator, its on the todo list after the fuel pump install
do a tee in the middle of the oil feed line before the csc
That Novi sounds awesome in the video. Subed for moar.
