Thread: Well there goes my L67 harmonic balancer...
Results 1 to 20 of 20
  1. #1 Well there goes my L67 harmonic balancer...
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    At least I hope that's what it is. Heard a VERY loud rattling under the hood only at idle and in gear. In the car it seems to go away when in neutral or park. Snatched off the SC belt....still rattling.
    Snatched off drive belt...rattling still.
    Not seeing metal flakes on the dipstick. Rattling seems loudest on passenger side of engine bay.
    Ugh....used parts.
    04+ L26
  2. #2 Re: Well there goes my L67 harmonic balancer...
    Could be a broken flex plate too, inspect it for cracks.
  3. #3 Re: Well there goes my L67 harmonic balancer...
    If you look at the front face of the balancer, it'll usually show cracks and if you pull/push on the belt, you'll see the outter ring move. That's how you can tell it's a balancer.
  4. #4 Re: Well there goes my L67 harmonic balancer...
    Sep 2012
    North Carolina
    OK I'll try checking it that way too once I get the car into the shop at work.
    Sent from my SPH-D710 using Tapatalk 2
  5. #5 Re: Well there goes my L67 harmonic balancer...
    Sep 2012
    North Carolina
  6. #6 Re: Well there goes my L67 harmonic balancer...
  7. #7 Re: Well there goes my L67 harmonic balancer...
    Winner! Easy to fix. Pop the belt.. yank the hb.. put on new..put belt back on.
  8. #8 Re: Well there goes my L67 harmonic balancer...
    Sep 2012
    North Carolina
    Yup easy fix. Swapping over the L26 HB until I get the new one this weekend. Is there much difference between the L67 and L32 HBs?
  9. #9 Re: Well there goes my L67 harmonic balancer...
  10. #10 Re: Well there goes my L67 harmonic balancer...
    No they are the same. I know its a little more spendy but the metal one from zzp is well worth the money, just make sure to get the standard sized one not the 5% od one, the 5% od one requires use of a spacer for the oil neck or else you will have one hell of a time putting belts on and you will need to dent your oil filter.
  11. #11 Re: Well there goes my L67 harmonic balancer...
  12. #12 Re: Well there goes my L67 harmonic balancer...
    St. Louis
    Be sure to line up the crank key with the balancer BEFORE you hammer the crank bolt back onto it. I know it sounds dumb, but it happens.
  13. #13 Re: Well there goes my L67 harmonic balancer...
    A little too often.
  14. #14 Re: Well there goes my L67 harmonic balancer...
    Sep 2012
    North Carolina
    Ha no I knew better than that. L26 balance is on until pay day.
  15. #15 Re: Well there goes my L67 harmonic balancer...
    Come payday..ask yourself. If these things last 13+ years commonly.. why change it again?
  16. #16 Re: Well there goes my L67 harmonic balancer...
    Sep 2012
    North Carolina
    Then line up the crank key and hammer it on.
  17. #17 Re: Well there goes my L67 harmonic balancer...
    Sep 2012
    North Carolina
    Or are you hinting SSM90?
  18. #18 Re: Well there goes my L67 harmonic balancer...
  19. #19 Re: Well there goes my L67 harmonic balancer...
    Sep 2012
    North Carolina
    Lol getting a new one
  20. #20 Re: Well there goes my L67 harmonic balancer...
    Omaha, NE
    I would just jb weld that one back together...
  1. new harmonic balancer, now got KR
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2012, 07:31 AM
  2. Harmonic Balancer-no Stock??
    By diamondz101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2011, 08:18 PM
  3. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
  4. Harmonic balancer puller
    By TorqueAutoMotiv in forum Shops and Community Heroes
    Last Post: 10-02-2010, 03:49 AM
