Thread: Pipe Degree for air ram intake?
Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 81 to 100 of 145
  1. #81 Re: Pipe Degree for air ram intake?
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    Sent from my SM-N910T using Tapatalk
  2. #82 Re: Pipe Degree for air ram intake?
    Donating Users GoldGTP's Avatar
    Sacramento, CA
    Put some zip ties on it and spray it with carb cleaner for leaks...
    If you still have leaks, you need some smaller I.D. tubing/vac line for both sections...
    Where about in NOLA are you? I pass through there every so often for work (Baton Rouge)...
  3. #83 Re: Pipe Degree for air ram intake?
    Enfield, CT
    Quote Originally Posted by ScottyDoggs View Post
    this pipe works well with a 97-98 year.
    wow, how did I forget you went all bumble bee on the motor? lol
  4. #84 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    Quote Originally Posted by GoldGTP View Post
    I stay on the Westbank we should meet and you could help me out
  5. #85 Re: Pipe Degree for air ram intake?
    Quote Originally Posted by HighOctaneRacing View Post
    went fsic and a 3.0 and 42 injectors as well. your little l36 is loving life lol
  6. #86 Re: Pipe Degree for air ram intake?
    Enfield, CT
    Well I'm happy to see it's getting the life it deserves. No matter how hard I tried to get the mods to make much more power, funds always had to go into something else.
    Sent from my LG G3
  7. #87 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    Where is the output speed sensor located
  8. #88 Re: Pipe Degree for air ram intake?
    why in the hell are you looking at that? get the damn car scanned already, you have codes because your light dont work.......codes hold the key to your issue, but your wont get the damn thing scanned.
  9. #89 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    I can't get it scanned it's not drivable do you know where the speed sensors are on the transmission
  10. #90 Re: Pipe Degree for air ram intake?
    Sacramento, CA
  11. #91 Re: Pipe Degree for air ram intake?
    Quote Originally Posted by Jason97GrandprixGT View Post
    your wasting your time, get it scanned one way or another. the beauty of obd2 is you get a fault code. 95% of the time you follow the code and its fixed. but your keep side stepping the most important part of any diagnosing. rule one, scan the car.
  12. #92 Re: Pipe Degree for air ram intake?
    04 Comp G.
  13. #93 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    I researched the symptoms of a bad vehicle speed sensor and it says speedometer needle not working and gear shifting problems and that's the problems that I'm having
  14. #94 Re: Pipe Degree for air ram intake?
    now google a maf issue and your'll see the same thing....like i said, wasting your time. if you want it fixed, get it scanned.
  15. #95 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    The vehicle speed sensor connector wires are bare and have nothing covering them some of the strands are cut also so I think that's why my car wasn't shifting gears. And would that cause it to shut down while I'm driving
  16. #96 Re: Pipe Degree for air ram intake?
    well any bare wires are sign of bad things. dont think its the cause of stalling tho. once again, get it scanned if you want to fix it.
  17. #97 Re: Pipe Degree for air ram intake?
    GXP Level Member
    Mar 2015
    Tomball
    I thought you said that was the last time Scotty?
    Jeff
  18. #98 Re: Pipe Degree for air ram intake?
    Kemmerer, Wyoming
    <----------------------- kicks the horse one more time
  19. #99 Re: Pipe Degree for air ram intake?
    clearly it needs to be pounded into his thick skull how to go about repairing things.
    said it on all 4 pages of this thread, get it scanned, not only in this thread..... in about all the other 10 threads as well.
  20. #100 Re: Pipe Degree for air ram intake?
    Kemmerer, Wyoming
    it boggles my mind this situation exists
  1. Intake pipe/BOV questions...
    By GTPChristopher in forum Turbo
    Last Post: 12-16-2015, 04:59 PM
  2. 4" JMP or ZZP intake pipe
    By CrazyGuy03 in forum Wanted To Buy - Parts
    Last Post: 06-11-2015, 07:14 PM
  3. Intake pipe from a z3 turbo kit
    By Swiggles in forum Wanted To Buy - Parts
    Last Post: 06-01-2014, 08:26 AM
  4. 08 Altima 3.5 CVT w/Intake,test pipe,& tune
    By pontiacman22 in forum Track Sessions and Kills
    Last Post: 10-20-2008, 03:51 PM
