Re: Pipe Degree for air ram intake?
Put some zip ties on it and spray it with carb cleaner for leaks...
If you still have leaks, you need some smaller I.D. tubing/vac line for both sections...
Where about in NOLA are you? I pass through there every so often for work (Baton Rouge)...
ScottyDoggs
wow, how did I forget you went all bumble bee on the motor? lol
GoldGTP
I stay on the Westbank we should meet and you could help me out
Sent from my SM-N910T using Tapatalk
HighOctaneRacing
went fsic and a 3.0 and 42 injectors as well. your little l36 is loving life lol
ScottyDoggs
Well I'm happy to see it's getting the life it deserves. No matter how hard I tried to get the mods to make much more power, funds always had to go into something else.
Sent from my LG G3
Where is the output speed sensor located
why in the hell are you looking at that? get the damn car scanned already, you have codes because your light dont work.......codes hold the key to your issue, but your wont get the damn thing scanned.
ScottyDoggs
I can't get it scanned it's not drivable do you know where the speed sensors are on the transmission
Jason97GrandprixGT
your wasting your time, get it scanned one way or another. the beauty of obd2 is you get a fault code. 95% of the time you follow the code and its fixed. but your keep side stepping the most important part of any diagnosing. rule one, scan the car.
ScottyDoggs
I researched the symptoms of a bad vehicle speed sensor and it says speedometer needle not working and gear shifting problems and that's the problems that I'm having
now google a maf issue and your'll see the same thing....like i said, wasting your time. if you want it fixed, get it scanned.
ScottyDoggs
The vehicle speed sensor connector wires are bare and have nothing covering them some of the strands are cut also so I think that's why my car wasn't shifting gears. And would that cause it to shut down while I'm driving
well any bare wires are sign of bad things. dont think its the cause of stalling tho. once again, get it scanned if you want to fix it.
I thought you said that was the last time Scotty?
Jeff
<----------------------- kicks the horse one more time
clearly it needs to be pounded into his thick skull how to go about repairing things.
said it on all 4 pages of this thread, get it scanned, not only in this thread..... in about all the other 10 threads as well.
ScottyDoggs
it boggles my mind this situation exists
