Sent from my SM-N910T using Tapatalk
Put some zip ties on it and spray it with carb cleaner for leaks...
If you still have leaks, you need some smaller I.D. tubing/vac line for both sections...
Where about in NOLA are you? I pass through there every so often for work (Baton Rouge)...
why in the hell are you looking at that? get the damn car scanned already, you have codes because your light dont work.......codes hold the key to your issue, but your wont get the damn thing scanned.
I researched the symptoms of a bad vehicle speed sensor and it says speedometer needle not working and gear shifting problems and that's the problems that I'm having
I thought you said that was the last time Scotty?
Jeff
clearly it needs to be pounded into his thick skull how to go about repairing things.
said it on all 4 pages of this thread, get it scanned, not only in this thread..... in about all the other 10 threads as well.
