Thread: Pipe Degree for air ram intake?
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 41 to 60 of 145
  1. #41 Re: Pipe Degree for air ram intake?
    Kemmerer, Wyoming
  2. #42 Re: Pipe Degree for air ram intake?
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    Quote Originally Posted by ScottyDoggs View Post
    the one that looks like a condom on a soft dick...... off the tb, below the iac sensor.
    It have 2 lines under the iac sensor is it the top or bottom hole
    Sent from my SM-N910T using Tapatalk
  3. #43 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
  4. #44 Re: Pipe Degree for air ram intake?
    Donating Users GoldGTP's Avatar
    Sacramento, CA
    Both vac lines appear "suspect"...
  5. #45 Re: Pipe Degree for air ram intake?
    the top one, the hard line is loosely fitting inside the rubber one.
    the one to the tranny looks kind weak too, but hard to tell from this angle.
  6. #46 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    Show me a picture of yours
  7. #47 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    The one on the tranny doesn't fit into the hole
  8. #48 Re: Pipe Degree for air ram intake?
    mines not really the same as yours. my evap is on the back. fat hose to tb, smaller hose pushed inside it, then smaller hose to hard line. its the one bending backwards in the sun glare.
  9. #49 Re: Pipe Degree for air ram intake?
    Kemmerer, Wyoming
    Quote Originally Posted by Jason97GrandprixGT View Post
  10. #50 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    By the line not fitting directly in the whole cause my tranny to Rev high but barely gain speed
  11. #51 Re: Pipe Degree for air ram intake?
    you need to fix them, those are vac leaks and will cause all your issues. and that throttle cable fix that too. take the zip ties off, put the one back in the hole in the bracket.
    zip tie it to the bracket if need be, not together.
  12. #52 Re: Pipe Degree for air ram intake?
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    Anybody else notice a ticking sound during acceleration from these short intakes or is it just me?
  13. #53 Re: Pipe Degree for air ram intake?
    Oct 2014
    portland oregon
    the zip ties are keeping his cable in line with the channel in the bracket.if he cuts them the cables will separate, rub on the bracket and break. i dont think there is a way to put a new plastic retainer on the cable. i believe the only fix is a entire jy cable.
  14. #54 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    What size vacuum hose should I replace the hard line with and what size to get for the top and bottom holes under the iac
  15. #55 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    Quote Originally Posted by wowitsfast View Post
    I'm at the junk yard now how to remove the entire cable
  16. #56 Re: Pipe Degree for air ram intake?
    pinch the square block on the fire wall woth pliers and pull it out. you need to unhook the cable from the gas pedal, look up its rather easy to get the cable off the arm.
  17. #57 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    I have the cable off the cable how to get it off the pedal
  18. #58 Re: Pipe Degree for air ram intake?
    most of the time its a slot you need to line up and remove it from, ive done many but never a w body. all are so simple to figure out.
  19. #59 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    Thanks I pulled it off that's why my car wasn't accelerating properly huh
  20. #60 Re: Pipe Degree for air ram intake?
    take the vac lines too if you can get them off with cracking them. the one to the tranny maybe hard to come by, its a 97 only thing.
  1. Intake pipe/BOV questions...
    By GTPChristopher in forum Turbo
    Last Post: 12-16-2015, 04:59 PM
  2. 4" JMP or ZZP intake pipe
    By CrazyGuy03 in forum Wanted To Buy - Parts
    Last Post: 06-11-2015, 07:14 PM
  3. Intake pipe from a z3 turbo kit
    By Swiggles in forum Wanted To Buy - Parts
    Last Post: 06-01-2014, 08:26 AM
  4. 08 Altima 3.5 CVT w/Intake,test pipe,& tune
    By pontiacman22 in forum Track Sessions and Kills
    Last Post: 10-20-2008, 03:51 PM
