Quote Originally Posted by ScottyDoggs View Post
that split is your problem. you need to hit a parts store, advance sells the best little t's. you need a Y and some vac line that fits the tb, then some smaller line to push inside the fat line, the Y to the other two small lines and the new line off the tb.
you'll need to cut or pull off the old factory rubber end off the hard lines, then put a inch or so of new vac line on the end of the hard lines to the Y.
i just told you how to make a replacement. for less then 5 bucks too mind you.
Quote Originally Posted by suitercrew View Post
So theres two hoses that become one at the throttle body and then one go to the evap pruge solenoid and the other goes to the top of the fuel pressure regulator. Does anyone have a part # for this? I tried to custom make one but its not working out well.
Sent from my LG-D851 using Tapatalk
your kidding right? this is 3 times..........
