Thread: 3800 series 2 Air box Removal
Results 1 to 9 of 9
  1. #1 3800 series 2 Air box Removal
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    I'm trying to install a open cone spectre air filter with aluminum tubing but first how to remove my airbox
    Sent from my SM-N910T using Tapatalk
  2. #2 Re: 3800 series 2 Air box Removal
    Unbolt it??
    I don't remember exactly where and what bolts there are but it's not rocket science.
  3. #3 Re: 3800 series 2 Air box Removal
    Feb 2010
    TN
    Take out filter there are 3 bolts under it
  4. #4 Re: 3800 series 2 Air box Removal
    Sep 2014
    New Orleans
    The screws have a weird looking shape I'm not sure what kind of flat head to use
  5. #5 Re: 3800 series 2 Air box Removal
    iirc mine was 3 13 mm bolts holding it down. they may have a torx head in the middle of the bolt. whats throwing you off.
  6. #6 Re: 3800 series 2 Air box Removal
    Jan 2014
    AR
    Once you remove the top half of the box, you can probably just pull up on the bottom half briskly to pop it loose. It has drive rivet type push clips holding rubber bushings to the box. If you lift up the PCM you see the heads of the clips. Don't mess with it from underneath, just yank the box up and the bushings pop out of the sheetmetal holes and stay attached to the box.
  7. #7 Re: 3800 series 2 Air box Removal
    Sep 2014
    New Orleans
    Thanks I removed it I'm trying to install the right degree of pipe to the coupler on the throttle body now. Can you tell me what degree of pipe to get and the perfect length size
  8. #8 Re: 3800 series 2 Air box Removal
    hes got a 97-98 box, its not quite the same mounting as a 99 up. ive ripped out a few 01's. the 97-98 aint gonna happen like that.
  9. #9 Re: 3800 series 2 Air box Removal
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
  1. 04 gp gt 3800 series 3 oil pan?
    By Timboslice in forum Engine
    Last Post: 11-03-2015, 07:14 PM
  2. How to tell the difference between a 3800 Series II and Series III engine/ L67 vs L32
    By DoUEvenShift NoBroItsAuto in forum Introductions/Noob Questions
    Last Post: 03-14-2014, 01:12 AM
  3. Will a series 1 3800 tranny fit a series 2
    By 2002grandprixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2012, 01:06 AM
  4. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
  5. 01 GP GT 3800 Series II
    By searcyfarms in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2009, 01:22 PM
