Thread: Idle dropping and bouncing??
Page 1 of 3 123 LastLast
Results 1 to 20 of 50
  1. #1 Idle dropping and bouncing??
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Not everytime but pretty frequently if i rev it when in park as soon as i let go of the accelerator rpms will drop really low and bounce back up. This has also happened at a light when i was stopped engine was idling fine right in the 700-750 range then when i went to give it gas rpms dropped really low then shot back up.
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: Idle dropping and bouncing??
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Check for vacuum leaks, clean the tb, and check the maf sensor. Any codes?
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  3. #3 Re: Idle dropping and bouncing??
    Oct 2015
    No codes i just got some carb cleaner to clean the tb and maf
  4. #4 Re: Idle dropping and bouncing??
    St. Louis
    Don't use the carb cleaner on the MAF. Use MAF cleaner on it. The TB is ok. If you have some electronics parts cleaner around you could use that on the MAF.
  5. #5 Re: Idle dropping and bouncing??
    Oct 2015
    Ok thanks. So ten minutes in im disconnecting the throttle body and theres two hoses that conjoin into one at the throttle body and where it conjoins there is a huge slice down the middle the two other hoses lead to the evap purfe solenoid and the fuel pressure regulator. Could this be a cause?
  6. #6 Re: Idle dropping and bouncing??
    Oct 2015
    Is there supposed to be puddles of oil in the valleys of the intake manifold and is the upper manifold supposed to have oil spray all over it?
  7. #7 Re: Idle dropping and bouncing??
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by suitercrew View Post
    Yes, the PCV valve does that. Mine had it when I did the LIM. Not sure about the UIM though.
  8. #8 Re: Idle dropping and bouncing??
    Oct 2015
    Why would they make it like that? What if you never changed it?
  9. #9 Re: Idle dropping and bouncing??
    Apr 2015
    Because GM. And change what, the PCV? Take it out and shake it. If you hear it rattle, then it's good and you don't need to replace it.
  10. #10 Re: Idle dropping and bouncing??
    that split is your problem. you need to hit a parts store, advance sells the best little t's. you need a Y and some vac line that fits the tb, then some smaller line to push inside the fat line, the Y to the other two small lines and the new line off the tb.
    you'll need to cut or pull off th eold factory rubber end off the hard lines, then put a inch or so of new vac line on the end of the hard lines to the Y.
  11. #11 Re: Idle dropping and bouncing??
    Oct 2015
    Well the one hose that goes to the purge solenoid has that fuel line connector on it so i thought it might be a "special order" kind of part unless that tip just pops off the hose?
  12. #12 Re: Idle dropping and bouncing??
    i just told you how to make a replacement. for less then 5 bucks too mind you.
  13. #13 Re: Idle dropping and bouncing??
    Oct 2015
    O ok i see what your saying now. Ok thanks scotty sorry for the confusion
  14. #14 Re: Idle dropping and bouncing??
    Oct 2015
    Hey so im doing the rear vc gasket since its alot easier access with everything off but whats up with the gaskets on the bolts themselves because there breaking when i take them off and my new vc gaskets didnt come with any
  15. #15 Re: Idle dropping and bouncing??
    the rubber ring around the bolt is called a grommet. ask for them at the parts store.
  16. #16 Re: Idle dropping and bouncing??
    Oct 2015
    Ok thanks scotty, have to make a trip to the parts store anyway cause they sold me the wrong lim gasket ugh.
  17. #17 Re: Idle dropping and bouncing??
    make sure its a metal lim gasket.
  18. #18 Re: Idle dropping and bouncing??
    Apr 2015
    I got a factory replacement Y-hose from the junkyard for like $3 if you choose that route.
  19. #19 Re: Idle dropping and bouncing??
    Enfield, CT
    No it's not "cause GM". Many manufacturers use PCV valves. It's your responsibility to maintain your car properly. Just take it out and check it once a year.
    Also I've used 4 different brands of PCV valves and the only one that has worked flawlessly is AC Delco.
    Sent from my LG G3
  20. #20 Re: Idle dropping and bouncing??
    Enfield, CT
    Also make sure you use Teflon paste on the LIM bolts and your to spec.
    Sent from my LG G3
  1. rough idle and bouncing rpm gauge
    By Flip97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2014, 01:57 PM
  2. 99 GTP, RPM's bouncing at 11-1600
    By AKGTP19 in forum General Tech Discussion
    Last Post: 03-15-2013, 06:49 AM
  3. Bouncing projectors
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-19-2010, 08:34 PM
  4. high-pitched whistle and bouncing idle
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-28-2010, 07:58 AM
  5. 94 GTP gas smell and bouncing idle
    By rw53104 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-17-2010, 02:21 PM
