Thread: Idle dropping and bouncing??
Results 21 to 40 of 50
  1. #21 Re: Idle dropping and bouncing??
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Teflon paste? And its 89inch pounds right?
    Sent from my LG-D851 using Tapatalk
  2. #22 Re: Idle dropping and bouncing??
    Enfield, CT
    Yes the paste is highly recommened. Helps keep the oil from wicking up and seals the LIM bolts down. LIM Bolt torque spec is 132 inch lbs. Convert that to ft lbs and you have 11 ft lbs. I did mine at 15 ft lbs cause I used the AC Delco metal gaskets.
    Make sure you tighten the LIM bolts in sequence.
    89 inch pounds is for the UIM, not LIM. Tighten in sequence as well.
    Sent from my LG G3
  3. #23 Re: Idle dropping and bouncing??
    Oct 2015
    Ok thanks a lot!!
  4. #24 Re: Idle dropping and bouncing??
    its coolant, not oil your sealing off. lim bolts go into the water jacket of the heads.
  5. #25 Re: Idle dropping and bouncing??
    Enfield, CT
    Both.
    Sent from my LG G3
  6. #26 Re: Idle dropping and bouncing??
    Oct 2015
    So bolted the lim down to spec and in sequence but when i look at it i still feel like theres a little gap between the two is thus normal?
  7. #27 Re: Idle dropping and bouncing??
    Enfield, CT
    Wait did you put RTV in the 4 corners?
    Sent from my LG G3
  8. #28 Re: Idle dropping and bouncing??
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by HighOctaneRacing View Post
    No it's not "cause GM". Many manufacturers use PCV valves. It's your responsibility to maintain your car properly. Just take it out and check it once a year.
    Also I've used 4 different brands of PCV valves and the only one that has worked flawlessly is AC Delco.
    Sent from my LG G3
    He asked why the PCV puts oil in the LIM.
  9. #29 Re: Idle dropping and bouncing??
    Oct 2015
    Yes i put on the side rubber seal then the gaskets and then rtvd where the side seals meet the gaskets so 4 places
  10. #30 Re: Idle dropping and bouncing??
    i do a dab in all 4 corner's, the install the lim and rubbers, then 4 more dabs. smear it so it touched both gaskets int he corner. sh its sealed now.
  11. #31 Re: Idle dropping and bouncing??
    Oct 2015
    But is it normal to look like theres a little gap?
  12. #32 Re: Idle dropping and bouncing??
    Enfield, CT
    Tapatalk error. Switching to PC lol
  13. #33 Re: Idle dropping and bouncing??
    Enfield, CT
    Quote Originally Posted by suitercrew View Post
    Honestly a pic of this gap would be helpful. Your torque wrench is calibrated correctly?
    Sent from my LG G3
  14. #34 Re: Idle dropping and bouncing??
    gap where? pic? if took like 5-6 trips around the lim snugging up the lim bolts it should be down as far as its gonna go.
  15. #35 Re: Idle dropping and bouncing??
    Enfield, CT
    I did multiple trips around as well. Give the Teflon paste 20 mins to settle and do a re-torque.
    Sent from my LG G3
  16. #36 Re: Idle dropping and bouncing??
    Enfield, CT
    BTW Scotty, I love your response on post #34 lol. http://www.grandprixforums.net/threa...sket-job/page2
  17. #37 Re: Idle dropping and bouncing??
    lol
  18. #38 Re: Idle dropping and bouncing??
    Oct 2015
    So got it all done and put back together so far i havent seen any leaks and cant hear or notice a vac leak so i think im in the clear! Thanks for all the help guys!
  19. #39 Re: Idle dropping and bouncing??
    Enfield, CT
    No problem
    Sent from my LG G3
  20. #40 Re: Idle dropping and bouncing??
    Oct 2015
    So theres two hoses that become one at the throttle body and then one go to the evap pruge solenoid and the other goes to the top of the fuel pressure regulator. Does anyone have a part # for this? I tried to custom make one but its not working out well.
  1. rough idle and bouncing rpm gauge
    By Flip97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2014, 01:57 PM
  2. 99 GTP, RPM's bouncing at 11-1600
    By AKGTP19 in forum General Tech Discussion
    Last Post: 03-15-2013, 06:49 AM
  3. Bouncing projectors
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-19-2010, 08:34 PM
  4. high-pitched whistle and bouncing idle
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-28-2010, 07:58 AM
  5. 94 GTP gas smell and bouncing idle
    By rw53104 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-17-2010, 02:21 PM
