Thread: Idle dropping and bouncing??
Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
  1. #41 Re: Idle dropping and bouncing??
    Enfield, CT
    They definitely won't have that anymore. Its a discontinued part. Best advice for that is if you want an OEM one, find a local junk yard that has regals, gps, impalas, bonnevilles, montes, park aves, etc. All those cars run the 3800 motor. If you need help locating nearby junkyards, go here
    Car-part.com
    Sent from my LG G3
  2. #42 Re: Idle dropping and bouncing??
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ok thanks
    Sent from my LG-D851 using Tapatalk
  3. #43 Re: Idle dropping and bouncing??
    Quote Originally Posted by ScottyDoggs View Post
    that split is your problem. you need to hit a parts store, advance sells the best little t's. you need a Y and some vac line that fits the tb, then some smaller line to push inside the fat line, the Y to the other two small lines and the new line off the tb.
    you'll need to cut or pull off the old factory rubber end off the hard lines, then put a inch or so of new vac line on the end of the hard lines to the Y.
    i just told you how to make a replacement. for less then 5 bucks too mind you.
    Quote Originally Posted by suitercrew View Post
    So theres two hoses that become one at the throttle body and then one go to the evap pruge solenoid and the other goes to the top of the fuel pressure regulator. Does anyone have a part # for this? I tried to custom make one but its not working out well.
    your kidding right? this is 3 times..........
  4. #44 Re: Idle dropping and bouncing??
    Oct 2015
    No i just went to a couple different parts stored and ridiculously enough they didnt have hose that size they only dad fuel line so i grabbed some of the smallest tubing they had and a t and straight through fitting but its just not working well.
  5. #45 Re: Idle dropping and bouncing??
    Enfield, CT
    Windshield wiper fluid hoses should be sufficient.
    Sent from my LG G3
  6. #46 Re: Idle dropping and bouncing??
    advance auto has everything you need. never seen a parts store that din't have vac lines of all sizes.
    advance auto also has the best t's your gonna find. they got a wall full of nothing but vacuum line hard parts.
    this is what you want, and some vac line... http://shop.advanceautoparts.com/p/d...+f%2Ft%2Fy%2Fx
  7. #47 Re: Idle dropping and bouncing??
    Enfield, CT
    In terms of vac parts sure, not for everything else lol
    Sent from my LG G3
  8. #48 Re: Idle dropping and bouncing??
    true that lol
    i got every parts store but o'reilly's here. and a few you never heard of too lol not even napa has the wall of t/x/y's advance has.
  9. #49 Re: Idle dropping and bouncing??
    Enfield, CT
    That's weird, I've got 3 or 4 O'Reilly's in my state. A brand new one is almost finished 3 blocks from me right near NAPA LOL. They are gonna be pissed when I start threatening to take my business there when I don't get the price I want haha
    Sent from my LG G3
  10. #50 Re: Idle dropping and bouncing??
    ever see so many ap stores in one area like this,,,zoom in the dots just get more and more lol https://www.google.com/search?q=o%27...1&rlfi=hd:;si:
  1. rough idle and bouncing rpm gauge
    By Flip97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2014, 01:57 PM
  2. 99 GTP, RPM's bouncing at 11-1600
    By AKGTP19 in forum General Tech Discussion
    Last Post: 03-15-2013, 06:49 AM
  3. Bouncing projectors
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-19-2010, 08:34 PM
  4. high-pitched whistle and bouncing idle
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-28-2010, 07:58 AM
  5. 94 GTP gas smell and bouncing idle
    By rw53104 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-17-2010, 02:21 PM
