Re: Idle dropping and bouncing??
They definitely won't have that anymore. Its a discontinued part. Best advice for that is if you want an OEM one, find a local junk yard that has regals, gps, impalas, bonnevilles, montes, park aves, etc. All those cars run the 3800 motor. If you need help locating nearby junkyards, go here
Car-part.com
Sent from my LG G3
Ok thanks
Sent from my LG-D851 using Tapatalk
ScottyDoggs
that split is your problem. you need to hit a parts store, advance sells the best little t's. you need a Y and some vac line that fits the tb, then some smaller line to push inside the fat line, the Y to the other two small lines and the new line off the tb.
you'll need to cut or pull off the old factory rubber end off the hard lines, then put a inch or so of new vac line on the end of the hard lines to the Y.
ScottyDoggs
i just told you how to make a replacement. for less then 5 bucks too mind you.
suitercrew
So theres two hoses that become one at the throttle body and then one go to the evap pruge solenoid and the other goes to the top of the fuel pressure regulator. Does anyone have a part # for this? I tried to custom make one but its not working out well.
your kidding right? this is 3 times..........
No i just went to a couple different parts stored and ridiculously enough they didnt have hose that size they only dad fuel line so i grabbed some of the smallest tubing they had and a t and straight through fitting but its just not working well.
Windshield wiper fluid hoses should be sufficient.
Sent from my LG G3
advance auto has everything you need. never seen a parts store that din't have vac lines of all sizes.
advance auto also has the best t's your gonna find. they got a wall full of nothing but vacuum line hard parts.
this is what you want, and some vac line... http://shop.advanceautoparts.com/p/d...+f%2Ft%2Fy%2Fx
In terms of vac parts sure, not for everything else lol
Sent from my LG G3
true that lol
i got every parts store but o'reilly's here. and a few you never heard of too lol not even napa has the wall of t/x/y's advance has.
That's weird, I've got 3 or 4 O'Reilly's in my state. A brand new one is almost finished 3 blocks from me right near NAPA LOL. They are gonna be pissed when I start threatening to take my business there when I don't get the price I want haha
Sent from my LG G3
ever see so many ap stores in one area like this,,,zoom in the dots just get more and more lol https://www.google.com/search?q=o%27...1&rlfi=hd:;si:
