Thread: Built 4t65e - The results are in.
Page 5 of 12 FirstFirst ... 34567 ... LastLast
Results 81 to 100 of 238
  1. #81 Re: Jane's 4t65e - Starting to assemble
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Good sh!it!
    Sent from my SM-S820L using Tapatalk
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  2. #82 Re: Jane's 4t65e - Starting to assemble
    Mar 2014
    Tucson
    Thanks! I totally forgot about the Teflon ring installation on the input housing assembly. Not much to say. Here's those pictures
    Re-sizer on. Waiting for installation
  3. #83 Re: Jane's 4t65e - Starting to assemble
    Mar 2014
    Tucson
    Little more progress today. Reverse band, input housing and driven sprocket support in to check the total endplay.
    Almost 0.032" Was a little much
    Fortunately, I had the selective I needed on hand. Replaced a white with a brown. One of the benefits of building multiple transmissions. Spare parts.
    Toss it all back in, including the 2nd clutch drum, because hopefully it won't have to come back out.
    0.009"... We're good here
    Ready for this!!
    It's in. My new avatar
    It's good. (For now)
    That's as far as I can go up top until I get the 4th clutch hub.
  4. #84 Re: Jane's 4t65e - Starting to assemble
    Mar 2014
    Tucson
    I made a video too
    https://youtu.be/KSoo-yxkvgw
  5. #85 Re: Jane's 4t65e - Starting to assemble
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Should of said something about the 4th hub.....I think I have 3 of them (one new and 2 from transmissions I've torn apart)
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  6. #86 Re: Jane's 4t65e - Starting to assemble
    Mar 2014
    Tucson
    Quote Originally Posted by GMR Badass View Post
    Well, to be fair, I kinda did.
    Quote Originally Posted by BrandonHall10 View Post
    This fall/winter, I'm planning on building a transmission for my car.
    Here's what I'm planning on using for parts:
    PNH Torque convertor
    Master rebuild kit
    -New frictions, steels, seals, gaskets, and filter
    All bands
    Bonded spacer plate
    Torlon check balls
    Oversize 2nd steel plates x2
    Molded 2nd apply piston
    Molded 3rd apply piston
    TEP reconditioned reaction carrier - Original is out of spec
    300m iput shaft
    7/8" 2.93 single chain set
    Borg warner PCS
    Borg warner TCCS
    AC Delco shift solenoid x2
    Superior AFL valve repair kit
    Superior valve body kit
    Sonnax TCC relief valve
    Trans-go shift kit
    Dorman pan w/ drain plug - Junkyard poked the original
    Hardened 4th clutch hub
    Differential lube tube clamp
    Lube dam
    Round magnet
    Didn't even think about asking for one here. It's not a huge deal though. They're only $30 shipped. When we do my brother in laws trans, I'll send a laundry list of needed parts.
  7. #87 Re: Built 4t65e - Quality takes time
    Mar 2014
    Tucson
    So since I couldn't do anything else on the side, I moved to the bottom
    Thermal element in
    Filter seal 2-1 manual servo seal and 2-1 manual servo installed
    Check to make sure the servo pin engages the band
    Ready for the accumulator assembly
    All together
    But before I did this
    I did this, per the instructions
    Forward servo in
    Again, check for pin engagement
    Threw the filter in. James said go crazy with magnets. This is only the beginning
    HeliCoil kit, 4th clutch hub, and solenoids are on their way...
  8. #88 Re: Built 4t65e - Quality takes time
    Apr 2015
    NJ
    becareful with your placement of the magnets, there is a TSB for them interfering with the force apply motor if placed improperly.
  9. #89 Re: Built 4t65e - Quality takes time
    Mar 2014
    Tucson
    Hmmm... From the research I've done, the only TSB I see related to magnets and the PCS is one adding a magnet. Something about replacing the one thin square magnet with the new larger round magnet. Also adding another to the filter body (like shown). In fact, that's exactly how the 2 year old serta unit I pulled apart was configured.
    Do you have any more info on this? And thanks for the feedback!
  10. #90 Re: Built 4t65e - Quality takes time
    GT Level Member MyLittlePony's Avatar
    Mar 2015
    Franklin, TN
    Magnets for your magnets magnets!
    Looks good man, nicely done. The next trans I do is getting some PPG Dog Box love.
  11. #91 Re: Built 4t65e - Quality takes time
    Apr 2015
    NJ
    Same TSB, some of them online are missing paperwork regarding the magnet placement though. Placement is really what is critical here as there is reason for them being placed on certain areas of the pan, the new round magnets are what I would go with over the squares as the squares have a tendency to become overloaded quickly, that was the purpose of the TSB. While im sure that you probably wont hurt anything with the magnets where they are, I wouldnt risk potentially having an issue with interference from the magnets by going "hog wild" with them. The two on the plan are plenty trust me, having multiple magnets attached to the filter and in locations that werent originally designed for them could cause more issues then they help solve. Given how your building the trans I dont think your gonna have issues where the magnets need to scoop up a ton of material, and the rest the filter and regular maintenance can handle just fine. Hate to see you develop some phantom issue as a result of magnets.
  12. #92 Re: Built 4t65e - Quality takes time
    Mar 2014
    Tucson
    Quote Originally Posted by LS1Adam84 View Post
    Hey thanks! Yeah, Every time I've pulled a pan or disassembled a trans, the magnet (singular) was always beyond capacity. I plan to be super vigilant about fluid maintenance, so even if I had the standard magnet setup, I wouldn't worry about it getting overloaded. But they're $1.30 each, so why not, right?
    That dog box is in a whole different league from what I'm doing here!
    Quote Originally Posted by Spawne32 View Post
    That diagram you show for magnet placement seems to make sense. It places them close, or as close as possible, to the fluid dump points. Just my opinion though, not an engineer. I may still order up a doughnut mag, but only because it would go around the protruding portion of my drain plug. Extra insurance for that RTV to keep it from moving around in the aluminum pan. We'll see. I still have time to figure all that out. Like I say, I plan to keep a close eye on fluid condition. Having a pan with a drain plug will make it way more convenient to drop and inspect/clean everything.
  13. #93 Re: Built 4t65e - Quality takes time
    Mar 2015
    Franklin, TN
    Yeah It will be the first time i open up a manual gear box, but I am saving and should be able to pick up an R33 when they hit the 25 year mark, the only issue I have it the motor setup I want is in Australia and them Aussies are selective about who they sell to. Otherwise the gearbox is the standard manual that comes mated to the RB25 engines.
  14. #94 Re: Built 4t65e - Quality takes time
    Mar 2014
    Tucson
    I didn't understand half of what you just said.
    Anyhow, Got my solenoids today. Again... Our postal service... Sigh
    Fortunately, they were pretty well packed. They made it in tact.
    Old PCS vs new
    Old TCC PWM vs new.
    The shift solenoids are nothing special, so no pics of those.
    I'm certain they test the solenoids before they ship 'em, but I figured it wouldn't hurt to check anyway. Doesn't cost anything.
    The 1-2 shift solenoid goes back in the bag until I get the new 1-2 valve
    There sits my almost done valve body
    Leftovers
    Tossed the dipstick tube seal in. I've found that an O2 bung plug is the perfect size for keeping stuff out while it's being stored
    No clutch hub today. Hoping to see it tomorrow.
  15. #95 Re: Built 4t65e - Quality takes time
    Dec 2012
    Where 4T65E's were born
    Nice work. Your magnets post reminded me to get some before I do my shift kit. Honestly I don't think you'll have any issues from your magnets. I will put two where the tsb says, and I'll do a few on the bottom of the filter like you did. The filter is steel, therefore it will prevent the magnetism from going up past it. Not sure I'd want to install any more anywhere else, but that will be like 4 or 5 already, that's enough lol.
    Not sure what magnets to get, and from where. Think I'll use 2 hard drive magnets on the underside of the filter.
    Sold.
  16. #96 Re: Built 4t65e - Quality takes time
    I didn't see the filter collar install... did that happen on page 4?
  17. #97 Re: Built 4t65e - Quality takes time
    hangover park IL
    I have 4 neodymium magnets over near the diff drains, rtv'd to the aluminum pan, drain plug was helicoiled and modified for a neo rod for easy accumulation inspection.
    im very nearly to putting a bypass filter setup on the cooler to make sure the fluids clean even with that screen on the pump inlet.
    get the tiniest scratch inside the filter seal bore or a non flat pump and as soon as the filter starts to plug youll start sucking air, then wonder why your line pressure fluctuates
    ~James~ Psychotic Gearhead
  18. #98 Re: Built 4t65e - Quality takes time
    Mar 2014
    Tucson
    Thanks. I went with the generic square magnets because they were cheap and available. $1.38 at my trans shop vs $8 for the round GM magnet from Ebay. I thought about using Neo magnets, but I read somewhere about them losing their pull at higher temperatures. That could have just been someone trying to sound smart though. The other reason I went with standard magnets is their size. Sure, the Neo magnets are super strong, but they don't have as much surface area. I think they would fill up fairly quickly. Plus, it doesn't take much pull to grab a metal particle that's suspended in fluid. That's my theory anyway.
  19. #99 Re: Built 4t65e - Quality takes time
    Mar 2014
    Tucson
    Not sure what page Bill. Tapatalk vs web browser. (?) Post #87. I kinda glossed over it.
    I should have posted a picture of just the seal. It's kind of important. I did take one though. Here it is
  20. #100 Re: Built 4t65e - Quality takes time
    Good to see...I concentrated on only page 5 today
  1. A Stray cat ripped open my screen and welcomed himself into my home
    By acidcrashdburnd in forum Off Topic Discussion
    Last Post: 06-13-2012, 08:48 AM
  2. Taz's Offical Summer/Fall build list.
    By Taz Magister in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 01:23 PM
  3. my build, need opinions
    By nascartech in forum General Tech Discussion
    Last Post: 10-03-2011, 10:53 PM
  4. ScreamsOfTheSouth Build / Need Opinions
    By z3r0 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2011, 10:24 AM
  5. Lookin for opinions here.. Engine build
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2009, 08:11 AM
