Thread: 3.69 gears installed! but issues...
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: 3.69 gears installed! but issues...
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    the more i watch that video it almost seems like the TC is locking up right after the shift then unlocking after a few seconds
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  2. #22 Re: 3.69 gears installed! but issues...
    Are you still setting codes?
  3. #23 Re: 3.69 gears installed! but issues...
    St Thomas Ontario
    just got a scanner today but forgot it in the truck at work..... ill find out tomorrow
  4. #24 Re: 3.69 gears installed! but issues...
    St Thomas Ontario
    scanner says 0 dtc codes. but i only drove the car 35 miles since i last reset the pcm, should i drive it more?
  5. #25 Re: 3.69 gears installed! but issues...
    St Thomas Ontario
    going to put the car off insurance untill spring, overkill is across the country so he cant come scan the car incar to recheck the tune, im kinda thinking the valve body gaskets arent sealing properly anyway... my friend and I took the trans apart in the car so it took HOURS to try and line up the gaskets for the valvebody properly and im wondering if they are actually sealing correctly...so I am going to save up for a reputable trans shop to take it apart to find out what happened.... only thing I can do at this point..
  1. intercooler, 42 lb injectors, and north star tb installed and having issues.
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2014, 10:08 PM
  2. Stainless Steel Brake Lines (Installed, Issues)
    By FriboRage in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2014, 12:15 AM
  3. Retrofits installed, having issues, please help!
    By ffball33323 in forum Visual/Body Modifications
    Last Post: 04-02-2014, 12:10 PM
  4. Headers installed, stuttering issues now
    By tu8i1o7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2011, 10:17 PM
  5. Installed plog (and DP) and now issues! (w/vid)
    By SliceTheRice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 07:03 PM
