the more i watch that video it almost seems like the TC is locking up right after the shift then unlocking after a few seconds
Are you still setting codes?
just got a scanner today but forgot it in the truck at work..... ill find out tomorrow
scanner says 0 dtc codes. but i only drove the car 35 miles since i last reset the pcm, should i drive it more?
going to put the car off insurance untill spring, overkill is across the country so he cant come scan the car incar to recheck the tune, im kinda thinking the valve body gaskets arent sealing properly anyway... my friend and I took the trans apart in the car so it took HOURS to try and line up the gaskets for the valvebody properly and im wondering if they are actually sealing correctly...so I am going to save up for a reputable trans shop to take it apart to find out what happened.... only thing I can do at this point..
