My friend and I put on a ZZP plog the other day and for the most part everything seemed to go well. I drove the car around and it seemed fine. Then when I went to go give it some good throttle I got this weird backfiring sputtering going on. I've been suspecting that I've had a clogged cat for some time so I before I freaked out about it I went and had the 3" catted DP installed to see if the cat was the problem. After the DP install, it's doing the exact same thing. It idles just fine and if you drive it conservatively, you would never guess something was wrong.
In this vid you can see that if you take the RPMs to 4.5 is starts doing that sputtering thing. It seems like it just might be the rev limiter, but if I'm at a light and then pin it, it will do the same thing at lower RPMs (just not consistently like in the vid. It will sputter for a second and then move on). Similarly, if I'm on the freeway cruising along at 2 RPMs and then pin it the car will shift down, sputter a bit and then take off with no problem. I spoke to another friend and he suspects the coils are the cause, but I'm at a loss as to how putting in a plog could blow my coils!
Please take a look (listen) to the vid and let me know if you have any ideas at all! (If you have good computer speakers with decent bass range, you'll hear it better). Like I say, this could very well just be a video of the rev limiter working like it should but I don't know if I can effectively video whats going on while I'm driving. This is just to give you a sense of what I'm hearing when I put the engine under a heavier load.
Thank you!!
