Thread: intercooler, 42 lb injectors, and north star tb installed and having issues.
Results 1 to 20 of 21
  1. #1 intercooler, 42 lb injectors, and north star tb installed and having issues.
    Kemmerer, Wyoming
    I installed a north star throttle body, 42 lb injectors, and an intercooler. on the highway under a heavy load, the car hesitates. I think the car hesitates because it is running too rich. the car also has a lopey idle even though the cam is stock.<span style="font-family:arial;"><font size="4">
  2. #2 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    GTP Level Member buickman104's Avatar
    NYC
    Did you tune at all?
    The LQ4 maf readings are different from the stock maf. You need to tune for all the mods you did. Also if you have a scanner check for long term fuel trims. If it is pegged at 16.4+ then you have a vacuum leak and the pcm is dumping fuel for the extra unmeasured air.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    GT Level Member dezebe1's Avatar
    May 2013
    Dallas TX
    Whats up with your boost bypass valve....every time you hit the throttle the body of it moves too, not just the valve?? Did you tighten it??
    Team JB-Weld
  4. #4 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    Kemmerer, Wyoming
    Im using a zzp tune, they should have adjusted for the maf and injectors. I will have to tighten the bbv, I thought it looked funny.
  5. #5 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    NYC
    Check for vacuum leaks. Large enough vacuum leaks give the engine a lopey idle.
  6. #6 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    Kemmerer, Wyoming
    the LT b1 stays at 16.4 when im idling, but when im driving around it fluctuates up and down. the BBV is tightened down, its the black part that dosent stay seated. how do I get it to stay seated?
  7. #7 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    You have a vacuum leak. Gotta find it. That'll fix your rich issue and your idle and what not.
    04 GTP -HAI, 1.9 rockers.
  8. #8 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    NYC
    Quote Originally Posted by johntremell View Post
    Yup, you have a vacuum leak. If you are all sealed up it should fluctuate between -3 to +3 and mainly sit a 0. Time to break out the carb cleaner.
  9. #9 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    May 2013
    Dallas TX
    The body of the BBV is bolted to the supercharger with 2 10mm bolts
    Team JB-Weld
  10. #10 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    Kemmerer, Wyoming
    Those bolts are right, it's only the black part that does not stay flat on the mount
    Sent from my KFJWI using Tapatalk
  11. #11 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    If the bbv is bolted fast then it's broken and needs replaced.
  12. #12 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    Kemmerer, Wyoming
    I replaced the vacuum lines going to the BBV and going from the BBV and secured the BBV to the bracket. The car is running real good now. I am still planning on a custom in car tune and I am hoping to drop to a 3.1" pulley.
  13. #13 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    Kemmerer, Wyoming
    I think I may have inadvertently rtv'd my pcv when I installed the intercooler. here are some pictures of what I see when I look down into the pcv on the supercharger case.
    is this what it is supposed to look like?
    intercooler, 42 lb injectors, and north star tb installed and having issues. Attached Images
  14. #14 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    rut ro shaggy.....time to pull it ic and blower off. a few scooby snacks and she'll be back up and runny.
    or maybe the scooby snacks were the cause???? lol
  15. #15 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    Kemmerer, Wyoming
    so I put the rtv in the wrong places?
  16. #16 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    every pic ive seen they make a cirle around the pvc holes in the ic and blower.
  17. #17 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    Kemmerer, Wyoming
    so this one dosent allow enough air flow
  18. #18 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    it looks plugged up. it run better with the oil fill cap off?
  19. #19 Re: intercooler, 42 lb injectors, and north star tb installed and having issues.
    Mercer, Pa
    With the PCV plugged it should run fine. You don't get positive air flow across the engine.
    If the back port is open and the front port is plugged you put to much vacuum to the engine and the front seal will squeal. It is being sucked in.
  20. #20 intercooler, 42 lb injectors, and north star tb installed and having issues.
    Mercer, Pa
    Take the PCV valve and the spring out. I think there may also be a plastic piece under the spring. See if you can pull the RTV up. The vacuum flow direction is up into the supercharger.
    Reach down into the hole with a drill bit and knock it loose. Pull or vacuum the RTV.
  1. North Star Throttle Body
    By sseilmnop in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2015, 08:23 AM
  2. How and what is needed to add a North star to a gen 3 l67
    By thunder71173 in forum General Tech Discussion
    Last Post: 05-21-2011, 02:35 PM
  3. ported north star casing
    By homerunhitter629 in forum General Tech Discussion
    Last Post: 03-08-2011, 10:46 AM
  4. North Star parts
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-03-2011, 01:07 AM
