Thread: Need to confirm trans issues rather than sensors.
Results 1 to 5 of 5
fastline Need to confirm trans issues... 08-28-2015, 01:35 PM
mguzzo Re: Need to confirm trans... 08-28-2015, 01:53 PM
BillBoost37 Re: Need to confirm trans... 08-28-2015, 02:07 PM
fastline Re: Need to confirm trans... 08-28-2015, 02:44 PM
fastline Re: Need to confirm trans... 08-30-2015, 04:16 PM
  1. #1 Need to confirm trans issues rather than sensors.
    Jul 2015
    usa
    2005, 3.8L, 135K,
    Posted a while back and just need to confirm I don't have something sensor related going in with this car. Has the typical oscillation in 4th with TCC locked or unlocked, I can't really tell. Also at random, car will seem to hang in a taller gear at a stop and slam back to 1st when you take off.
    I recently unplugged the battery for other repairs and was obviously shifting much harsher. I also noticed when first starting the car that it died, then started and rpms drop almost to stall, then catches itself and levels off.
    NOT DTC codes have been set but I have not been able to review the live data from the Trans yet to determine TCC state, duty, etc. I just need to confirm the trans is toast before I go further. I know some have mentioned other things like an engine miss but I cannot really detect a miss and certainly runs like a top when the pedal down.
  2. #2 Re: Need to confirm trans issues rather than sensors.
    GT Level Member mguzzo's Avatar
    Buffalo NY
    sounds like you have a few things happening.
    http://www.tripleedgeperformance.com...cillation.html
    This generally happens when the valve body has excess wear in the TCC regulated apply valve area but also has other causes. Excessive fluid leakage in this area of the valve body causes TCC apply pressure loss and can lead to uncontrollable TCC operation which causes the engine rpm to bounce up and down a bit. This problem is noticed most after driving a while and speeds between 42 and 70mph and in 4th gear.
    http://www.tripleedgeperformance.com...ward-Cold.html
    One of the most common problems I have found after the milege gets over roughly 60K miles. The scenario.... You are driving in traffic for a while OR your car has sat for a while and is a cold startup. You put the car in Drive range and it wont move, or if driving you come up to a stop light and in heavy traffic and the light turns green and SUPRISE!!! You are holding up traffic with a car that wont go anywhere. The most common cause of this problem is a worn out inner surface of the Input clutch piston.
    When you disconnect the battery the PCM loses its adaptive shift knowledge and will shift harshly until it "learns" from your driving habits.
    The startup issue could be a dirty IAC pintle, dirty MAF sensor, or vacuum leak.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: Need to confirm trans issues rather than sensors.
    Clean your TB, if your plugs/wires are old then swap them out, and clean the maf. Any codes for the engine or map?
  4. #4 Re: Need to confirm trans issues rather than sensors.
    Jul 2015
    usa
    No codes have ever came up on diagnostic scan. I did also try tapping the brake durring the OD oscillation to unlock the TC and it does not do a thing. That puzzles me at the moment.
  5. #5 Re: Need to confirm trans issues rather than sensors.
    Jul 2015
    usa
    UPDATE!!!
    I really need to be driving this car, not the other half! Finally drove it today to realize it IS NOT doing to TCC oscillation AT ALL! I was very happy about that, which may help in getting closer to the find. HOWEVER, I did note that after some driving, the trans will start shifting too firm in all gears. This happened after I stopped, used reverse, then put car in 1st for a distance, then back to drive. After that it was shifting hard.
    Mamma also indicates at stops, sometimes at take off there is a hard bang. I have experienced this and believe the trans is holding in a taller gear and waits until throttle to downshift to first for some reason. I suspect all the hard shifting and failure to downshift as a high line pressure? But why?
    One of the biggest developments is when I fired it up today, I could detect a slight miss so I am going to throw plugs/wires at it. Still seems to run out fine in higher RPMs but I can detect something slight. It is no quiet, I can't hear what it is really doing.
    However, there is more to this story. Unplug battery and TCC oscillation goes away?
  1. Dynamat on Kock sensors and Trans?
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2015, 10:28 AM
  2. Help Confirm Diagnosis?
    By TuKoolGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2014, 01:36 PM
  3. trans surging and trans temp issues.
    By kawasaki22106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-08-2013, 08:29 AM
  4. How to confirm the car is not a 04 Comp G?
    By rizer in forum General Grand Prix Discussion
    Last Post: 12-04-2012, 03:27 AM
  5. Confirm my knocking
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 08-08-2012, 06:08 AM
