Thread: How to remove trans dipstick grommet from fill hole
Results 1 to 12 of 12
  1. #1 How to remove trans dipstick grommet from fill hole
    May 2015
    Joliet, Illinois 60436
    How did some of you guys remove the grommet from the fill hole? It's a 2001 gtp if that helps at all
  2. #2 Re: How to remove trans dipstick grommet from fill hole
    theres a o ring, thats it. it will stay on the tube most of the time.
  3. #3 Re: How to remove trans dipstick grommet from fill hole
    May 2015
    Mine didn't come out with the tube. So I've been trying to fish it out in the mean time
  4. #4 Re: How to remove trans dipstick grommet from fill hole
    GXP Level Member
    Mar 2015
    Tomball
    That's odd mine has a large grommet as well. It sticks up nearly 1/4" and right now is leaking slightly. I was going to change it when I do the shift kit if I ever get out of here. I figured it would be easier to change once the pan was down and I could see the bottom side.
    Jeff
  5. #5 Re: How to remove trans dipstick grommet from fill hole
    it should be right at the top of the hole, if theres nothing there it may not have been there, or it fell in, if it fell in its in the pan, not a big deal.
  6. #6 Re: How to remove trans dipstick grommet from fill hole
    Quote Originally Posted by ScottyDoggs View Post
    Scotty's never seen it
    It's not an o-ring, it's not going to fall in ... It's ... well like a top hat. If you need to get it out. Reach down and push in on the sides a little ..grab it and pull it out.
  7. #7 Re: How to remove trans dipstick grommet from fill hole
    Mar 2014
    Tucson
    Sometimes called a "top hat" seal cause.... well... It looks like a top hat.
    I have to believe it would take some sort of miracle for i to fall INTO the transmission. More likely it came out with the dipstick tube the last time it was pulled. Regardless, it just pushes in place. Held in place by the dipstick tube.
  8. #8 Re: How to remove trans dipstick grommet from fill hole
    May 2015
    I got it out guys! And yep Brandon, it does look like a lincoln top hat. It only took me half an hour laying on the engine to wiggle the thing out.
  9. #9 Re: How to remove trans dipstick grommet from fill hole
    Arizona
    You guys are so lucky you don't have a 10mm bolt holding the tube down
  10. #10 Re: How to remove trans dipstick grommet from fill hole
    Quote Originally Posted by 91parkave View Post
    Every single one I have seen does.
  11. #11 Re: How to remove trans dipstick grommet from fill hole
    GXP Level Member
    Mar 2015
    Tomball
    I had one without the 10mm bolt, but since it didn't it rubbed a hole through one of the lines on the rack and that was one of the issues the car had when I bought it. The 2 little spot welds broke and the bolt and bracket were still on the block. Replaced it with a good one now don't have to worry about that again for a while.
    Jeff
  12. #12 Re: How to remove trans dipstick grommet from fill hole
    mine has a 10 mm bolt.
  1. Trans dipstick compatibility L67 on L32
    By J57ltr in forum General Tech Discussion
    Last Post: 05-24-2015, 02:37 PM
  2. Trans Dipstick with headers question
    By gtpterp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2013, 08:06 AM
  3. Trans dipstick question
    By theone2043 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 12-17-2009, 01:38 AM
  4. How much Dex 6 to have on hand to fill dry trans?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2008, 01:34 PM
  5. Supercharger Fill Hole Bolt Stripped
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 06:20 AM
