Thread: Help Confirm Diagnosis?
Results 1 to 3 of 3
  1. #1 Help Confirm Diagnosis?
    SE Level Member TuKoolGTP's Avatar
    Nanamo, BC, Canada
    My car has had a hard start problem. Doesn't want to start with just a key turn. Takes a little press of the gas peddle to start. Runs fine once started.
    I swapped the Fuel Pressure Regulator with my other car. After swap the car starts fine. The car also had a p102 MAF code. I pulled the MAF sensor and it was obviously dirty. Cleaned it and replaced it. The car has also had a downstream O2 sensor code, can't remember the number.
    Here is the question.....
    The other car I swapped with still starts fine also. Could the fuel pressure regulator be causing a rich condition that doesn't cause a start problem right away? But will after some time? Should I replace it?
    Custom CAI | PowrTuner | AL 104s | TBS | 3" DP | Res Del | 180 TS | 3.6 | PEM
  2. #2 Re: Help Confirm Diagnosis?
    clean your TB. re scan, get the codes, post em up, or look them up.
  3. #3 Re: Help Confirm Diagnosis?
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    Any luck? Did you check the idle air control valve?
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  1. Power steering problem how to confirm it's the rack and not pump
    By SJAndrew in forum General Tech Discussion
    Last Post: 10-21-2013, 09:43 PM
  2. How to confirm the car is not a 04 Comp G?
    By rizer in forum General Grand Prix Discussion
    Last Post: 12-04-2012, 03:27 AM
  3. Confirm my knocking
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 08-08-2012, 06:08 AM
  4. LCA diagnosis????
    By Mr D in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2012, 10:46 AM
  5. Just to confirm the pulley size with my current growing list of junk
    By ls6velless454 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2010, 07:10 PM
