Thread: Transmission Fluid and Filter change at 98k?
Results 1 to 3 of 3
  1. #1 Transmission Fluid and Filter change at 98k?
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    I recently purchased an 02 GP GTP and as far as I know the trans fluid and filter has never been changed. I do however know the pan needs to be pulled and have a new gasket put on it, it's leaking. I know it's an age old debate about flushing a transmission with high miles, but how about a fluid and filter change for these transmissions at the low range of high miles?
  2. #2 Re: Transmission Fluid and Filter change at 98k?
    if the fluid is still red and dont smell burnt have at it. just a pan drop, dont flush it.
    see if the pan bolts are loose, that maybe why its leaking.
    if you dont have a thick gasket @ the pan, its not stock anymore. stock one is re usable. new ones are thin and suck. so it may have been replaced at some point.
  3. #3 Re: Transmission Fluid and Filter change at 98k?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    If you change your mind about changing the fluid and filter, put a bottle of Lucas Transmission Fix in it to help slow the leak and prevent further damage.
  1. Transmission fluid change, Dealership or Typical Oil Change place?
    By bjornbjorn in forum General Grand Prix Discussion
    Last Post: 09-20-2013, 10:38 PM
  2. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  3. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  4. Hardshifting after new fluid and filter change.
    By Pontiacman76 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2010, 05:47 PM
  5. Tranny fluid and filter change
    By chevyy1212 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2010, 03:49 PM
