Thread: Surging TCC after some repair work. Scratching head on this one.
Results 1 to 5 of 5
  1. #1 Surging TCC after some repair work. Scratching head on this one.
    Jul 2015
    usa
    Someone else's car. Car overheated a couple times. I replaced the water pump and water elbow that is above water pump and a common issue. Some time after repairs, car started to develop surging when TCC is locked. Will do it at a wide range of RPMs and speeds and seems to only do it when TCC should be locked and you are lightly accelerating or going uphill, etc. Once unlocked, it seems to shift ok. On occasion, it seems the car fails to make it back to 1st and will clunk when taking off which suspect is bumping back to first. It will also, at random, shift very harsh, then just shift fine.
    The odd clunk at take off and harsh shift is VERY random but the surging is very consistent though the severity seems to vary some. I personally just drove it 300 miles and just work with it to keep it from oscillating but I usually just add more pedal to totally unlock TCC.
    Before we go and tear the trans all apart, I am wondering if there is anything else I need to be checking? I did do some base level testing while plugged in and TPS looks very smooth, no wandering. I did not really look at MAF too much. I am also wondering about any simple wiring issues? I was going to go plug into a tech II to observe the TCC duty cycle and slip but maybe something else?
    I have read some considered a misfire but I cannot really lean on that too much as I would think the ECM would find that. It otherwise runs great. WOT pulls as it should through all gears.
    Woops, 2006 grand prix, 130k miles. no codes
  2. #2 Re: Surging TCC after some repair work. Scratching head on this one.
    Mar 2014
    Tucson
    Welcome to the forum!
    Probably going to need a little more info. Year, make and model? How many miles? Any stored or pending codes?
    Does this accurately describe what it's doing?:
    http://www.tripleedgeperformance.com...cillation.html
  3. #3 Re: Surging TCC after some repair work. Scratching head on this one.
    Jul 2015
    usa
    Updated... Sorry.
    I did read that info and does seem to fit but I have heard of similar issues being fixed with everything from plugs/wires to vac leaks. My gut is saying it is the TCC solenoid but pressure solenoid is probably also a cuplrit as the harsh shifting would be in there too. Just makes me wonder about possible power issues to the TCM or trans? Unlikely?
  4. #4 Re: Surging TCC after some repair work. Scratching head on this one.
    hangover park IL
    AFL valve bore wear.
    have the same thing.
    ~James~ Psychotic Gearhead
  5. #5 Re: Surging TCC after some repair work. Scratching head on this one.
    Clean the TB, make sure plugs and wires aren't old and that the coil posts are clean. Also scan for any misfires when it's happening.
    Very often people misdiagnose TCC issues for ignition system breakdown or a car that hasn't had reasonable maintenance
  1. 7" Flip screen head unit. Will it work?
    By austinshanks in forum Audio, Security & Visual Electronics
    Last Post: 04-22-2012, 09:51 AM
  2. head gasket repair
    By CHAMPS97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2011, 04:47 PM
  3. Head Gasket Repair
    By routzahn06gtp in forum Introductions/Noob Questions
    Last Post: 10-18-2010, 02:26 PM
  4. Looking at some head-work, don't understand some things
    By copgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2009, 11:23 AM
