Thread: Looking at some head-work, don't understand some things
Results 1 to 20 of 22
  1. #1 Looking at some head-work, don't understand some things
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    So I'm looking to buy a set of ported heads off of another community member. Everything that is done to the heads I understand, except one thing, here is the quote from him:
    "They were milled 0.015 which with the 0.052 headgaskets caused a decrease of 0.025 and increased the compression 0.5 to 9.0:1 on the GTP (factory 8.5:1)
    (i think that math is right, i know whatever it is.. it comes out to a 9.0:1 ratio)
    Of course you could always run the stock thickness or even thicker than stock gaskets to decrease the raise in compression, but it ran good with the extra bump. "
    So am I going to run into any problems running this setup??? An increased compression ratio certainly going to effect some things right????
    For all your 3800 needs:
  2. #2 Re: Looking at some head-work, don't understand some things
    Banned - Busted For Scamming
    Feb 2009
    You will be fine with the increased CR. You are intercooled so i doubt it will knock. The only by product is more power
  3. #3 Re: Looking at some head-work, don't understand some things
    i would run it with stock head gaskets anyway. it just means that the bottom of the head (the side that goes towards the pistons) was milled down a little bit so there is less area in the cylinders (making a higher compression ratio).
    they will work fine.
  4. #4 Re: Looking at some head-work, don't understand some things
    Wooster, Ohio
    ^ agreed, run stock gasket and intercooled shouldn't be an issue, unless you turbo later without a bottom end! then it will just be like a fireworks show!
  5. #5 Re: Looking at some head-work, don't understand some things
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    Quote Originally Posted by Pittman06 View Post
    What are you trying to say? If your saying the engine can't handle high boost, your incorrect. ZZP used an L36 block and took their car into low 9's if not high 8's in the 1/4 mile before they switched to an L67 block
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  6. #6 Re: Looking at some head-work, don't understand some things
    Not a great place to use as a source... they have a history... of blowing things up.
  7. #7 Re: Looking at some head-work, don't understand some things
    Schaumburg, IL
    Since you seem pretty enlightened on the subject, please show me another company or person that has as much experience as them. I can name about 8 people or so that use L26 or L36 shortblocks and run in the 11's
  8. #8 Re: Looking at some head-work, don't understand some things
    Charles City, IA
    So you have built a 8 sec gp? Their pcms may not be great, but they know a lot about the 3800 and make a lot of pats that you will buy.
    SMGPFC Two Nipple General
  9. #9 Re: Looking at some head-work, don't understand some things
    i would never use a low compression block EVER. even if i was going with a turbo setup.
  10. #10 Re: Looking at some head-work, don't understand some things
    In no way am I doubting the strength of our shortblocks, just ZZP's overall credibility.
    IRCC, that 8 second car didn't hold up too well.
    Again, why does everyone always jump and say, "HAVE YOU BUILT AN 8 SECOND GP?"
    The validity of a statement should not be affected by who its coming from.
    Same reason someone with 21038403298324 posts shouldnt always be trusted versus someone with "only" 200.
  11. #11 Re: Looking at some head-work, don't understand some things
    Jan 1970
    Maquoketa, Iowa
    That 8 second car is holding up just fine..? They used the same short block over the years until just recently they switched to one of their built blocks. There is not much else that can be done with the car, so it will be street driven a lot more next year...
  12. #12 Re: Looking at some head-work, don't understand some things
    Dec 2008
    Canada
    Quote Originally Posted by FoSHO99 View Post
    X2 and I recall someone saying on CGP that he had taken his son out for ice cream one day and it behaved fine on the street? I am not 100% I could be wrong but I am far to lazy to find it.
  13. #13 Re: Looking at some head-work, don't understand some things
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    i thought i heard turbo tim doing that in the 8 second prix that Matt M owns
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  14. #14 Re: Looking at some head-work, don't understand some things
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by 1998xGTP View Post
    Quote Originally Posted by bbptech View Post
    Not sure if Tim ever took it out, but Matt drove the car home when they first broke into the 8's. Just this year Matt took it out on the street with his kid to get ice cream. The car has pretty much hit its limits but is still streetable. Matt just bought a monte carlo not too long ago that I think he will be building a rwd setup in, just not sure when.
  15. #15 Re: Looking at some head-work, don't understand some things
    they had a lot of money and proprietary parts being used. with that amount of money i could build a really fast car too. thats why tim king said **** it and just did it all on a firebird and went much faster for cheaper.
  16. #16 Re: Looking at some head-work, don't understand some things
    Lol... displacement makes going fast easier and cheaper.
  17. #17 Re: Looking at some head-work, don't understand some things
    he had a firebird with a v6. but still, RWD and a turbo go a long way.
  18. #18 Re: Looking at some head-work, don't understand some things
    I'll bet it sounds better than the FWD counterpart.
  19. #19 Re: Looking at some head-work, don't understand some things
  20. #20 Re: Looking at some head-work, don't understand some things
    Ignoring the video was put together by an idiot... thats impressive!
  1. People who dont understand what a Low gas light is...
    By TorqueAutoMotiv in forum The Rant Forum
    Last Post: 08-20-2009, 10:19 AM
  2. help me to understand
    By vailskier3 in forum General Tech Discussion
    Last Post: 03-22-2009, 09:50 AM
  3. Engine Guru's, Help Me Understand Ignition Timing
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2008, 04:28 AM
