Thread: 99 gtp trans into a 2004 gtp?
Results 1 to 8 of 8
  1. #1 99 gtp trans into a 2004 gtp?
    Sep 2011
    MI
    Title says it all. I have a 99 gtp that needs a body and can get a 2004 gtp that needs a transmission. will it work?
  2. #2 Re: 99 gtp trans into a 2004 gtp?
  3. #3 Re: 99 gtp trans into a 2004 gtp?
    It will not be a direct swap.
  4. #4 Re: 99 gtp trans into a 2004 gtp?
    you would need to change the rad too cause the trans cooler lines are not the same too.
  5. #5 Re: 99 gtp trans into a 2004 gtp?
    You can change the fittings on the trans or radiator if you needed to.
    It's not a hard thing to do.
  6. #6 Re: 99 gtp trans into a 2004 gtp?
    Sep 2011
    MI
    So other than the range position sensor everything else should be ok? I'm not worried about radiator connectors, that's a simple fix. There isn't a difference in PCM control of the trans or anything?
    Thanks for the link Scotty useful info for sure
  7. #7 Re: 99 gtp trans into a 2004 gtp?
    PCM controls and valve body are different for sure.
  8. #8 Re: 99 gtp trans into a 2004 gtp?
    Valve body, channel plate, and wiring harness is different.
    Swap all that out and you'll be good as long as your gear ratio is correct.
  1. 2000 trans in a 2004 car
    By 2004l67 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2015, 02:21 PM
  2. 2004 built trans with only 300 miles
    By 1quick in forum For Sale - Parts
    Last Post: 07-03-2014, 11:28 AM
  3. 2004 Regal with New Trans
    By MidnightBlue in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2012, 09:34 AM
  4. 2004 trans... is it on its way out?
    By thebeezknees in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-13-2012, 08:37 PM
  5. 2004+ trans
    By HOPPY in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-09-2009, 01:55 AM
