Thread: Acceptable tcc slip rpm
Results 1 to 20 of 20
  1. #1 Acceptable tcc slip rpm
    Buffalo
    Curious when scanning what is an acceptable amount , if any , of tcc slip? While cruising or under wide open throttle ?
  2. #2 Re: Acceptable tcc slip rpm
    It should be close to none when locked in 4th gear.
  3. #3 Re: Acceptable tcc slip rpm
    Buffalo
    I don't think I let it shift into 4th under wot but I will check my 4th locked slip. Thanks !
  4. #4 Re: Acceptable tcc slip rpm
    Well you wouldnt want to shift into OD at full throttle anyway.
    But while locked in 4th on the freeway, slip should be very very small or none at all.
  5. #5 Re: Acceptable tcc slip rpm
    Buffalo
    Yeah lol I know that
    I was just concerned at the top 3rd wide open I though I saw slip rpm show up
  6. #6 Re: Acceptable tcc slip rpm
    GXP Level Member
    Mar 2015
    Tomball
    I was showing about 1650 taking off normally and locked up in 4th gear was about 20-30 rpm. I'm curious about this too and was going to ask the same thing. Under full throttle launches I would see a peak of 1950 or so.
    Jeff
  7. #7 Re: Acceptable tcc slip rpm
    Slip depends a lot on the lockup strategy and converter clutches. Then factor in all the other various items the pcm sees and you end up with a little slip here or there depending on what is going on.
  8. #8 Re: Acceptable tcc slip rpm
    hangover park IL
    pcm will command anywhere from 0 to 150 rpm slip depending on the load at tcc "apply"
    its mainly to minimize NVH and isnt used on my crap, i set lockup to 100% duty cycle and deal with the "5th shift" and sometimes the lugging vibration at low rpm's in 3rd/4th (where you can almost feel the individual cylinders firing
    ~James~ Psychotic Gearhead
  9. #9 Re: Acceptable tcc slip rpm
    Apr 2015
    Columbus, OH
    Quote Originally Posted by Turbocharged400sbc View Post
    I'd like to see your apply/release tables. I've been only getting kr when the tcc locks at low rpms and having a hard time tuning it out.
    Top Swapped 01 Imp
  10. #10 Re: Acceptable tcc slip rpm
    Buffalo
    Very strange issue here as well. The more you dig into the throttle while the convertor is locked , I occasionally would see 1-2* kr before it would release. Now you can adjust it to release early but I kept it the same because something odd happened.
    Once I filled the intercooler and ran it, it never came back.
  11. #11 Re: Acceptable tcc slip rpm
    Apr 2015
    Columbus, OH
    What do you mean by "something odd"?
    Top Swapped 01 Imp
  12. #12 Re: Acceptable tcc slip rpm
    Bob,
    Open bin file, insert my trans settings, Close bin file and load.
  13. #13 Re: Acceptable tcc slip rpm
    Buffalo
    I told you the "odd" part - once I filled my IC and ran it, it never came back.
  14. #14 Re: Acceptable tcc slip rpm
    Buffalo
    Bob,
    i could try and mess around with it again but my release / apply was tweaked many times - I just put it back to stock. I liked no lock up ever in 3rd too.
    Bill I gotta find your Dropbox again. Cause I would like to see your "boost" gauge in HPT .....
  15. #15 Re: Acceptable tcc slip rpm
    https://www.dropbox.com/sh/npa8brtuzoq3qps/jqYuBP0cv- love that trans tune. but you have no perf shift button, so you have to move the perf shift files to the normal files .
  16. #16 Re: Acceptable tcc slip rpm
    Apr 2015
    Columbus, OH
    Hmmm, not odd to me I guess. Pretty much expected.
    Top Swapped 01 Imp
  17. #17 Re: Acceptable tcc slip rpm
    Buffalo
    Well odd to me cause tbere was hardly any boost coming from the blower.
    which leads me to another question about PE. I can make boost under certain conditions before entering 40% throttle which is what my PE is set to - so 1-3lbs at a stoich AFR no kr .... Again all with the apply / release tables and why I dropped 3rd lock up all together.
    Scorty those hose files for 3.29s?
  18. #18 Re: Acceptable tcc slip rpm
    if you have your tranny wroked like one of them valve bodys, use the trand file from bills regal.
    if not theres another one in his name folder, or i could email you a bin with the trans tune to keep the searching down.
  19. #19 Re: Acceptable tcc slip rpm
    Buffalo
    I'll be home at noon thirty today and will look at it if you want to send it
    thanks!
  20. #20 Re: Acceptable tcc slip rpm
    Load trans settings
    Search on the usual BillBoost "ea sy" and then adjust for 3.29's.
    Ohhhh the 10 min this might take. It's painful
  1. Transmission Slip in low gears- Slip on stopping and acceleration
    By 9grandprixgtp in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 10-11-2013, 03:15 PM
  2. What amount of KR is acceptable?
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2013, 05:56 PM
  3. How much slip is ok?
    By fri3dchick3n in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2012, 02:00 PM
  4. 1st gear slip BAD
    By Jesse1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-04-2010, 06:34 PM
  5. Acceptable KR, stock PCM, L36
    By Sabrewings in forum PCM Tuning
    Last Post: 04-21-2008, 10:03 PM
