If you look close I covered the areas that I thought would rub and wrapped the with pieces of the leftover hose that I slit down the middle.
Took it for a drive tonight. Whereas normally it would top out at about 220 it did not break 200. Also the temp would actually go back down which never happened before. All in all I think its worth it.
Next two items on the list are a transgo kit and replacing the turn signal switch because the brights flash on and off over bumps and when I set the cruise control.
