Thread: Weird trans slipping...
Results 1 to 9 of 9
gagt3100 Weird trans slipping... 08-08-2013, 10:00 PM
BillBoost37 Re: Weird trans slipping... 08-09-2013, 05:57 AM
gagt3100 Re: Weird trans slipping... 08-09-2013, 11:02 AM
BillBoost37 Re: Weird trans slipping... 08-09-2013, 11:15 AM
gagt3100 Re: Weird trans slipping... 08-09-2013, 11:24 AM
gagt3100 Re: Weird trans slipping... 08-10-2013, 12:33 PM
gagt3100 Re: Weird trans slipping... 08-12-2013, 09:16 PM
gagt3100 Re: Weird trans slipping... 08-12-2013, 12:12 PM
91parkave Re: Weird trans slipping... 08-12-2013, 02:02 PM
  1. #1 Weird trans slipping...
    SE Level Member gagt3100's Avatar
    Mar 2012
    Milwaukee, Wisconsin, United States
    Ok so when I accelerate from a dead stop or roll say about less than 15 mph and floor it the transmission does not seem like it wants to shift it will hit the redline 1-3 times then shift. It only does it in 1st and when it is in D. If I go %90 throttle it shift just fine no shaking or anything. I do have tap shift and when i manually shift from 1st to 2nd and WOT it is just fine no matter where I shift in the gear. I am also currently in the process of installing a nitrous system in my car and right now the only thing I have messed with is the Throttle position wire and the wire seems to be fine but I will 2x check it in the morning. Fluid is perfect pink and full. Any thoughts? Electrical? bad clutch? Should I drop the pan and see? Oh also the rebuilt trans has 11k on it.
    Thanks Guys!
    Black 05 gxp. Cai 13.99 @100 2.2 60'
    3.29, Diablew TCM and PCM tuned, Catless DP, magnaflow catback. 390whp nitrous
  2. #2 Re: Weird trans slipping...
    throttle position will definately effect shifting. Is this new or has this been occuring for a while?
  3. #3 Re: Weird trans slipping...
    Mar 2012
    This is new bill :/
  4. #4 Re: Weird trans slipping...
    I'd think it's something you dinked with if it's out of the blue since you dinked
    Problem exists between seat and steering wheel.
  5. #5 Re: Weird trans slipping...
    Mar 2012
    Best quote! haha I'm going to save that one, never heard it! haha I will take a look with a ohm meter and see if the wire is all good
  6. #6 Re: Weird trans slipping...
    Mar 2012
    Here is a video I made, I am getting weird voltages. From what I have read it should be between 0 and 4 but its constantly above 8. ProblemWOT - YouTube
  7. #7 Re: Weird trans slipping...
    Mar 2012
    Alright, wires are good. There are 2 TPS wires , I did use your schematic when I originally did this . The green wire is the other TPS and its reversed voltages. I have no codes at all, none for the engine none for the trans :bang:
  8. #8 Re: Weird trans slipping...
    Mar 2012
    anyone have any thoughts? I'll mess with it today
  9. #9 Re: Weird trans slipping...
    Arizona
    Voyages don't play into your issue you should the pedal position at wot no more than 88% at idle it can be around 4-15% with out touching the pedal. Also remember that your tb system has 2 tps references , make sure your tapping the right wire. Also there 0-5 volts iirc. Check the tb swap I did if you need the wiring schematic.
    Edit: your original problem IMO lays in your tune. Talk to Lew see what he can do for you.
  1. Trans slipping bad
    By jrmac88 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-06-2013, 07:10 AM
  2. Uhhhhhh. Slipping trans?
    By nos4blood70 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-04-2013, 12:15 PM
  3. Trans Slipping
    By SVTf in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-28-2013, 08:17 PM
  4. Trans slipping into neutral?
    By zeppelin913 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-14-2011, 11:01 PM
  5. Trans Slipping - HELP!!
    By coolken84 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-01-2011, 01:17 PM
