Thread: Transmission running at 210*-240*!!!
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Transmission running at 210*-240*!!!
    04's in stock form on long driving will see 230*, this is true.
    Changing out the fluid and filter to a nice Syn (Cough Cough Amsoil) will help. Also many of use had our fans reprogrammed to kick on at 180* vs the Stock 210* (or whatever it is). This will help tremendously to bring your tranny temps down as well.
    I've seen as high as 235* when my car was stock and with Amsoil....now 205* is the most I see.
  2. #22 Re: Transmission running at 210*-240*!!!
    Quote Originally Posted by JoshsGTP View Post
    Thats how I scan!
    is that a Aeroforce Scan Gauge? i cant read the gauge but its in your sig.
  3. #23 Re: Transmission running at 210*-240*!!!
    Akron Ohio
    yep thats it!
  4. #24 Re: Transmission running at 210*-240*!!!
    that will be on my list down the road for sure, thanks.
  5. #25 Re: Transmission running at 210*-240*!!!
    Akron Ohio
    They are nice as hell, The best thing I have done to my car, I love it!
  6. #26 Re: Transmission running at 210*-240*!!!
    PA
    Quote Originally Posted by Lenny View Post
    your right its not... im not saying its ok if you run all the time at those temps. i usually see 160* - 180* depending on the outside temp, and how im driving. but sometimes hot happends
    Well then search around. There are many other sources to back up that information. It's almost "common knowledge."
    And yes, sometimes hot happens and you can't help that. But to spread misinformation like:
    Ive heard that around 260* is when bad things start to happen
    is not doing anybody any good. Transmission fluid starts to break down, or in your words, 'bad things happen' well before 260°. So to think and convey to someone that doesn't know that anything under 260° is safe is just wrong. Fluid starts to break down well before that.
    Yes, sometimes you can't help that your tranny gets hot. But with some preventative measures like a tranny cooler and synthetic fluid, you can prevent your transmission from getting to those dangerous temperatures over 220°.
    2001 GSE
  7. #27 Re: Transmission running at 210*-240*!!!
    Jul 2011
    Linden, MI
    Temperature gauge shows a little under half on the reading. I just changed trans fluid an filter yesterday. Getting coolant changed this week too. Hopefully these two things will get trans temp down.....
  8. #28 Re: Transmission running at 210*-240*!!!
    Moore,OK
    so how accurate are the trans temp readings on the DIC?
    is it the same as the computer sees?
    99 gtp
    14.7@92mph 2.1 60ft .290 r/t STOCK
    :SOLD: Mistake
    2005 GXP???
  1. Who's running low 14's?
    By Louie3 in forum Off Topic Discussion
    Last Post: 08-02-2010, 09:24 AM
  2. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  3. Amp running to 6x9's
    By crackercalgary in forum Audio, Security & Visual Electronics
    Last Post: 10-18-2009, 06:21 PM
  4. Got my car running!!!
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 08-02-2009, 01:58 PM
  5. Is 210 running hot?
    By NewImage in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2009, 11:11 PM
