Thread: Transmission running at 210*-240*!!!
Results 1 to 20 of 28
  1. #1 Transmission running at 210*-240*!!!
    Jul 2011
    Linden, MI
    My 2008 gp's trans runs at 210-240* in hot weather! This can't be normal, can it?
  2. #2 Re: Transmission running at 210*-240*!!!
    Waukesha, WI
    i see 209 at 100degree days, not 240 though
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: Transmission running at 210*-240*!!!
    Grand Island, Nebraska
    Ill check mine tomorrow during the day. pretty sure mine are over 200
  4. #4 Re: Transmission running at 210*-240*!!!
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I don't think mine have exceeded 180 F.
  5. #5 Re: Transmission running at 210*-240*!!!
    Pennsylvania
    Quote Originally Posted by klogan View Post
    Should probably never see more than 225*. Low on trans fluid? Is it bad? when was your last transmission flush with filter change?
  6. #6 Re: Transmission running at 210*-240*!!!
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    I was gonna say I get up to about 215ish on the really hot muggy days but never over
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  7. #7 Re: Transmission running at 210*-240*!!!
    whats the coolant running at?
  8. #8 Re: Transmission running at 210*-240*!!!
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    x2 on the coolant question
    For all your 3800 needs:
  9. #9 Re: Transmission running at 210*-240*!!!
    PA
    A rule of thumb has been that tranny fluid starts to break down at 220°F. So I always like to see mine below that. If you are running the newer Dexron VI fluid, you probably have a little more room to breathe. But not much. IMO, that's too hot.
    Check to see what the coolant temp is at that point. And if possible, add a tranny cooler.
    2001 GSE
  10. #10 Re: Transmission running at 210*-240*!!!
    Pennsylvania
    Quote Originally Posted by Zef_66 View Post
    This is not a solution to the problem.
  11. #11 Re: Transmission running at 210*-240*!!!
    Out West
    Sure it is
  12. #12 Re: Transmission running at 210*-240*!!!
    PA
    Quote Originally Posted by SlowNA06 View Post
    Why not? If his tranny is running hot because he is in 100° heat and sitting in traffic with the AC on, then it is a perfect solution to the problem.
    If he has a different issue that his tranny fluid is getting so hot, then no, it is not a solution. But it will probably help.
    I don't see a downside to installing a tranny cooler (other than the ZZP professed crap about a tranny line coming loose)
    2001 GSE
  13. #13 Re: Transmission running at 210*-240*!!!
    GT Level Member Lenny's Avatar
    Jul 2010
    41 R QR 51938 02935
    i was driving on I 70 in colorado through the mountians, and i saw 246* trans temp. coolant was running a little hot, but not bad. everything cooled off once i started going downhill. Once i stopped i checked all the fluids and everything was good. Ive heard that around 260* is when bad things start to happen
    2007 Grand Prix GXP
  14. #14 Re: Transmission running at 210*-240*!!!
    PA
    Quote Originally Posted by Lenny View Post
    Probably not the best source, but the best I could find in the minute of searching. Link.
    Automatic Transmission Fluid Temperature
    Automatic transmission fluid (ATF) has a life of about 100,000 miles at 175oF. At high temperatures, it oxidizes, turns from red to brown and exhibits a burnt smell. In addition to reducing the oil’s lubricating quality, high temperature produces a varnish on internal parts interfering with the operation of the transmission. Above 250oF., rubber seals harden, leading to pressure loss and leaks. Also, the transmission can slip. In the worst cases,
    clutches fail and costly repairs result. ATF manufacturers suggest that for every 20oF. increase in operating temperature above 175oF., the life of the fluid is cut in half. Hence at 195oF., oil life will be about 50,000 miles. Above 240oF., it becomes nil.
    2001 GSE
  15. #15 Re: Transmission running at 210*-240*!!!
    Jul 2010
    41 R QR 51938 02935
    your right its not... im not saying its ok if you run all the time at those temps. i usually see 160* - 180* depending on the outside temp, and how im driving. but sometimes hot happends
    2007 Grand Prix GXP
  16. #16 Re: Transmission running at 210*-240*!!!
    Akron Ohio
    I just checked mine I never see above 205
  17. #17 Re: Transmission running at 210*-240*!!!
    this maybe a dumb question, but how are you all checking the trans temp, is there a sensor and gauge combo, or through a scan of some sort?
  18. #18 Re: Transmission running at 210*-240*!!!
    latter is the only correct method.
  19. #19 Re: Transmission running at 210*-240*!!!
    and what type of scanner would that be?
    i wouldn't mind have such info at hand down the road.
    my gmc truck had a gauge for the trans temp and it was for sure nice to have when towing or snow plowing. as temps did vary a lot.
  20. #20 Re: Transmission running at 210*-240*!!!
    Akron Ohio
    Thats how I scan!
  1. Who's running low 14's?
    By Louie3 in forum Off Topic Discussion
    Last Post: 08-02-2010, 09:24 AM
  2. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  3. Amp running to 6x9's
    By crackercalgary in forum Audio, Security & Visual Electronics
    Last Post: 10-18-2009, 06:21 PM
  4. Got my car running!!!
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 08-02-2009, 01:58 PM
  5. Is 210 running hot?
    By NewImage in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2009, 11:11 PM
