Ok so im going to pull the trans out of my 97, i have a lift at my disposal, do you guys think it would be easier to pull the motor and trans assembly out, or disconnect the motor and leave it in? i dont have a support brace or anything..so in short is it alot more work to drop everything, or should i seperate it? Anything else to watch out for? Im also changing the rack and pinion while im at it. any comments or tips will be appriciated
