Thread: trans issue.....no 1st or overdrive
Results 1 to 20 of 24
  1. #1 Re: trans issue.....no 1st or overdrive
    SE Level Member glhtomni's Avatar
    iowa
    You are right. In a reply email from dave at triple edge performance mentioned that both shift solenoids and the tcc pwm solenoid all get their 12v ignition feed through that TCC fuse under the hood. Mine was blown. So I replaced, checked both sides of the fuse and got 12v. I drove a bit and rechecked and fuse was good. I cleared the ecu. By a scanner and as soon as I put it in reverse the cel lit back up. I rescanned immediately. And just the 1860 tcc. Pwm code popped back up. So I am believing that solenoid is bad and tripping the other 2 I am going to check some wiring with the meter tomorrow and if all is well ill be replacing every solenoid in the side cover. Any thoughts advice or suggestions?
  2. #2 Re: trans issue.....no 1st or overdrive
    Mercer, Pa
    Unfortunately it's not easy to pull the pan off. It's also pretty hard to ohm out the solenoids, you just can't see the pins on the tranny connector very well. I ended up pulling tranny out and did complete overhaul.
  3. #3 Re: trans issue.....no 1st or overdrive
    Quote Originally Posted by sseilmnop View Post
    For Ohming..I hit up a JY and got a body side of the harness. Then it's as easy as labeling the wires.
  1. Trans or Engine issue
    By chuy09 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-20-2010, 07:55 AM
  2. Trans Issue
    By theone2043 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-02-2010, 05:57 PM
  3. trans overdrive problem?
    By Viperhunter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-08-2009, 01:22 PM
  4. Am I having a trans issue?
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-02-2009, 01:56 PM
  5. trans. shuddering issue
    By monte0 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2009, 08:21 PM
