Thread: leaking pan
Results 1 to 5 of 5
  1. #1 leaking pan
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    I just recently changed my tranny fluid and filter. Like a good little boy, I poured in two quarts and waited to see if any leaks presented themselves. After a couple of days and no leaks I poured in the rest. Still, no leaks. After driving for a couple of days, it now seems to be leaking around the pan. I'd really like to not waste all that fluid I bought. Is there anything I can do? Can I maybe torque the nuts just a little tighter?
  2. #2 Re: leaking pan
    do you have the stock lifetime gasket on there or a replacement? The stock gasket has lines on it and metal embedded. It's the best gasket you can get. The bolts should be torqued to 10ft lbs or 120 inch lbs. Go much more than that and you'll hear an ugly sound of "SNAP". Then you'll have more fun getting the piece out.
  3. #3 Re: leaking pan
    Lakeside Park, KY
    I used the stock lifetime gasket. When I took the pan off, it had black RTV sealant around the whole pan edge.
  4. #4 Re: leaking pan
    If someone RTV'd it...it's garbage. Sorry.
  5. #5 Re: leaking pan
    Lakeside Park, KY
    Well, they didn't RTV the gasket or surfaces, just the seam.
  1. Leaking Oil ?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 12-30-2010, 11:29 AM
  2. Think im leaking coolant
    By blackgpgt in forum General Tech Discussion
    Last Post: 02-14-2010, 03:56 PM
  3. Leaking coolant.
    By c002529 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-16-2010, 12:21 PM
  4. leaking air
    By nyydmb12 in forum Tires & Wheels
    Last Post: 07-14-2009, 07:39 AM
  5. S/C Leaking???
    By jagamite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:53 PM
