Thread: trans issue.....no 1st or overdrive
Results 1 to 20 of 24
  1. #1 Re: trans issue.....no 1st or overdrive
    SE Level Member glhtomni's Avatar
    iowa
    yeah i read that and originally thought it could be that bad solenoid under the side cover. but i think it may be a speed sensor issue now. it makes sense that he smashed the fender into a guard rail and instantly the speedo stops working along with the trans shifting at the same exact time. going to pull the fender and look for said cut wire, repair, reset codes and see what happens.
  2. #2 Re: trans issue.....no 1st or overdrive
    The only wiring that would be speed sensor related to control the trans would be the VSS on the passenger side. If the wiring is messed up on teh driverside, check the Soleniod A wire from pcm to trans.
  3. #3 Re: trans issue.....no 1st or overdrive
    iowa
    it is on the pass side of the car, he said he noticed cut wires on that side when he replaced the fender but did nothing to the wires. so if the vss wires are cut, would the no speedo, CEL and no 1st gear or OD symptom be a likely cause?
  4. #4 Re: trans issue.....no 1st or overdrive
    No speedo, probably a cel and dunno on the rest. At that point your limpin or probably using the ISS instead. tough to say.
  1. Trans or Engine issue
    By chuy09 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-20-2010, 07:55 AM
  2. Trans Issue
    By theone2043 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-02-2010, 05:57 PM
  3. trans overdrive problem?
    By Viperhunter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-08-2009, 01:22 PM
  4. Am I having a trans issue?
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-02-2009, 01:56 PM
  5. trans. shuddering issue
    By monte0 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2009, 08:21 PM
