Thread: trans issue.....no 1st or overdrive
Results 1 to 20 of 24
  1. #1 trans issue.....no 1st or overdrive
    SE Level Member glhtomni's Avatar
    iowa
    i have a 99 grand prix gt with 158k on it i just picked up for free.
    i am very nechanical and could swap one if need be, but just wondering if this is a known problem.
    the car will take off in 2nd and shift to 3rd but will not shift into OD or shify back down into 1st, any tips on what to look for or do?
    also for worse case scenario, being a 99 gt, what other year/model trans will bolt in, fit and work with the ECU?
    thanks in advance
  2. #2 Re: trans issue.....no 1st or overdrive
    St. Louis
    Not shifting into OD is common. The splines on the 4th clutch hub get stripped out and you loose OD. You can still drive it like this, but the RPMs will be higher.
    Not sure on starting out/loosing 1st gear, never had to deal with that issue.
    If you decide to get a rebuild, contact Trannyman (Dave) at Triple Edge Performance. You shouldn't have to worry about a trans issue again.
    As far as swaps, anything from 98-03 should swap, and possibly some newer ones. Try a quick search on here and see what comes up as I'm pretty sure its been discussed.
  3. #3 Re: trans issue.....no 1st or overdrive
    SE Level Member Paul79UF's Avatar
    Florida
    I just wanted to add that apparently the 4th gear clutch hub issue was fixed for 2003.
    My car just lost OD too, so I've been reading a lot about the issue.
    So if you buy a used tranny on eBay, try to get a 2003 one.
    I'll probably just use my car around town and on limited highway trips until I can buy a new or barely used car. Usually take the wife's Corolla for long trips.
    FYI - My GTP revs to almost 3000 RPM at 75mph on the highway and the DIC shows that I'm getting 24-25 MPG without OD.
  4. #4 Re: trans issue.....no 1st or overdrive
    you can use a 03 tranny unless you have a 03 car.
    that tranny is alot different and wont work with other years.
    but you can still upgrade the 4th gear shaft in the other year (98-02) trans.
  5. #5 Re: trans issue.....no 1st or overdrive
    iowa
    well i think i may have gotten a lil lucky. when i posted this i hadnt even picked the car up yet. so after getting as new battery and starter for it and firing it up, i took it for a lil test spin, blew a brake line though.
    well i noticed the speedometer was not working and a check engine light was on, so i figured it may be the speed sensor that was bad causing the trans issue. so i called the PO and talked to him, he told me when he bumped the guard rail with it, the speedometer stopped working and the trans had funny shifts and when he replaced the fender he noticed a cut wire from the wheel speed sensor but didnt repair it. so i may be in luck with a easy fix.
    so with a cut speed sensor wire, whay would be the ill effect caused?
    i did get to drive it and it is definetly not taking off in 1st and not shifting to overdrive. even when i manually put it in first it is still taking off in 2nd gear.
  6. #6 Re: trans issue.....no 1st or overdrive
    Most likely the no 1st/4th is a bad soleniod A in the trans
    http://www.transtec.com/tech_insert/IS-4T65E-5.pdf
    Sounds like you lucked out on not buying it. Although for the right price.
  7. #7 Re: trans issue.....no 1st or overdrive
    iowa
    yeah i read that and originally thought it could be that bad solenoid under the side cover. but i think it may be a speed sensor issue now. it makes sense that he smashed the fender into a guard rail and instantly the speedo stops working along with the trans shifting at the same exact time. going to pull the fender and look for said cut wire, repair, reset codes and see what happens.
  8. #8 Re: trans issue.....no 1st or overdrive
    The only wiring that would be speed sensor related to control the trans would be the VSS on the passenger side. If the wiring is messed up on teh driverside, check the Soleniod A wire from pcm to trans.
  9. #9 Re: trans issue.....no 1st or overdrive
    iowa
    it is on the pass side of the car, he said he noticed cut wires on that side when he replaced the fender but did nothing to the wires. so if the vss wires are cut, would the no speedo, CEL and no 1st gear or OD symptom be a likely cause?
  10. #10 Re: trans issue.....no 1st or overdrive
    No speedo, probably a cel and dunno on the rest. At that point your limpin or probably using the ISS instead. tough to say.
  11. #11 Re: trans issue.....no 1st or overdrive
    iowa
    cool, in a bit ill have the fender off and seeing whats what and report back after.
  12. #12 Re: trans issue.....no 1st or overdrive
    Florida
    you can't use a 03 tranny unless you have a 03 car.
    Ok, thanks for the clarification.
  13. #13 Re: trans issue.....no 1st or overdrive
    iowa
    okay after replacing every single steel brake lines on it, i finally got it up to autozone for a CEL scan. got 3 codes back.
    p0753 1-2 shift solenoid
    p0758 2-3 shift solenoid
    p1860 tcc/pwm solenoid
    i did check the resistence on the pass side VSS sub section, it was good, traced it back to the harness with no visible damage.
    i really want to check into the wiring more first before just swapping in new solenoids.
    he said all was fine, he wiped out the fender/bumper/headlight on a guard rail instantly the speedo stopped working and the trans wasnt shifting properly, replaced the cosmetics, butt connected a few wires going to the headlights and turn signals and drove it in the current condition for a bit.
    the trans fluid is very clean and pink. the trans feels solid just isnt shifting correctly.
    does anyone have a link or tell me what to check for with my volt/amp/ohm meter and what i should see when i check the pins. electrical isnt my best subject, but im good and following directions and diagrams.
  14. #14 Re: trans issue.....no 1st or overdrive
    Mercer, Pa
    My SSEI had the solenoid go bad, I lost 1st and 4th but still had lock up in 3rd. Go to triple edge performance website Dave gives the pinout of wiring and a lot more trouble shooting info. Biggest problem is you just about have to pull tranny from car to get at the valve body.
  15. #15 Re: trans issue.....no 1st or overdrive
    Mercer, Pa
    There is a fuse that can blow also. My blew the fuse a couple times, which gave multiple tranny codes.
  16. #16 Re: trans issue.....no 1st or overdrive
    iowa
    You are right. In a reply email from dave at triple edge performance mentioned that both shift solenoids and the tcc pwm solenoid all get their 12v ignition feed through that TCC fuse under the hood. Mine was blown. So I replaced, checked both sides of the fuse and got 12v. I drove a bit and rechecked and fuse was good. I cleared the ecu. By a scanner and as soon as I put it in reverse the cel lit back up. I rescanned immediately. And just the 1860 tcc. Pwm code popped back up. So I am believing that solenoid is bad and tripping the other 2 I am going to check some wiring with the meter tomorrow and if all is well ill be replacing every solenoid in the side cover. Any thoughts advice or suggestions?
  17. #17 Re: trans issue.....no 1st or overdrive
    Mercer, Pa
    Unfortunately it's not easy to pull the pan off. It's also pretty hard to ohm out the solenoids, you just can't see the pins on the tranny connector very well. I ended up pulling tranny out and did complete overhaul.
  18. #18 Re: trans issue.....no 1st or overdrive
    Quote Originally Posted by sseilmnop View Post
    For Ohming..I hit up a JY and got a body side of the harness. Then it's as easy as labeling the wires.
  19. #19 Re: trans issue.....no 1st or overdrive
    iowa
    so for checking the voltage on the solenoids, do i do it with the key on or engine started?
    as a lil update, this morning it actually took off in 1st gear, in 1st manually. still no overdrive, so i believe the tcc pwm solenoid is the root cause, either way im planning on replacing all of them once i get around to lowering the trans, i know thats gonna be fun lol. i miss wrenching on my chrysler 2.2/2.5 turbos, very easy to get around the engine bay, i can swap one of those trannys in about 2 hrs or so.
  20. #20 Re: trans issue.....no 1st or overdrive
    You'll unhook the connector to the trans and test the trans side. I find it much easier if you hit a JY and get a piece of the wiring (piece that you'll unhook to test it) and then use your piece of connector/wiring to test it. Otherwise you are trying to get pins etc and that's a pain.
    So key off.
    Once you get the subframe down and lower the drivetrain..it's not so bad. Or maybe I've done it a few too many times?
  1. Trans or Engine issue
    By chuy09 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-20-2010, 07:55 AM
  2. Trans Issue
    By theone2043 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-02-2010, 05:57 PM
  3. trans overdrive problem?
    By Viperhunter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-08-2009, 01:22 PM
  4. Am I having a trans issue?
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-02-2009, 01:56 PM
  5. trans. shuddering issue
    By monte0 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2009, 08:21 PM
