Thread: trans. shuddering issue
Results 1 to 4 of 4
  1. #1 trans. shuddering issue
    NY
    To give a little quick history, I bought my present 97 GS regal with a GM reman. trans that after 4 months of owning it starting slipping. First I noticed it only on hard starts (shuddering out of the hole on hard launches), then it started to slip when downshifting into passing gear while driving. So last year I replaced the trans. with a 2001 LS regal trans with 20k on it, did the HD swap and tuned the pcm accordingly for the 3.29's. I also replaced the converter with a stock replacement GM converter new for a 2001. As of last fall things were fine. Now that winters over, I've been tuning it getting ready for the track, and I went to practice my launches and the trans. shuddered just like it did with the original trans. (almost feels like wheel hope, but it's definitely the trans). So I scanned some and I was able to duplicate the issue.
    So I tried something different by launching the car while I was in 1st using the shifter, instead of 3rd like normal. The problem disappeared. So right after I tried it in 2nd, 3rd and 4th and the issue was still their. I'm actually able to duplicate the problem power braking only slightly, basically tapping the gas real quick while holding the brake. No shuddering what so ever in 1st, but in any other gear from a dead stop it does it. Over all the trans. doesn't slip while driving, shift's perfect all the time and theirs no code at all. I'm kinda at a loss as to what this could even be....so any direction you guys can point me in to start ironing this issue out would be great
    2001 Regal-GMPP handling, shift kit, tuned, ported Gen3, 3.6, N*, SLP dual catback, Aeroforce
    70 Monte Carlo 12.5@109 waiting on new setup
  2. #2 Re: trans. shuddering issue
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    When you pull the shifter down into manual 1st the line pressure goes up quite a bit for extra holding power as well as an extra band is applied and these together give good engine braking holding power which is the intent. What tires are you using on the car at the track or is it doing this with an easy launch with street tires?
  3. #3 Re: trans. shuddering issue
    NY
    it's doing it with my street tires at the track/street driving..I jacked the pressures this weekend at the low end and it almost totally went away, but all I feel I'm doing is covering the underlining issue.
  4. #4 Re: trans. shuddering issue
    NY
    I raised the pressure up a tad more and all it doees now is make it shudder harder, what exactly could it be?
  1. Possible Final Thread, Trans Issue
    By GPSims39 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-09-2009, 09:52 PM
  2. another kr issue
    Last Post: 02-24-2009, 12:30 PM
  3. GTP pcm issue with ZZP
    By Regalgs98 in forum PCM Tuning
    Last Post: 02-18-2009, 02:16 AM
  4. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
  5. PM Issue
    By 04DetroitLS in forum Forum Bugs/Suggestions
    Last Post: 05-16-2008, 07:39 AM
