Thread: Installing Shift Kit issues
Results 1 to 20 of 43
Threaded View
  1. #12 Re: Installing Shift Kit issues
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Quote Originally Posted by rickisrad View Post
    I believe this is the spring you will need. if not follow the parts diagram. Rock auto should have it. Also make sure the lines are seated properly. http://www.w-body.com/topic/32115-4t...install-guide/
    ACDELCO 24203977 GM Original Equipment Info
    Category: Accumulator Spring
    $5.46
    take this info to every local parts store or auto shop/trans shop until one of them says they have one. That's your best bet...
    For the fluid, put in 6 quarts of the newest fluid. Start the car, on a level surface, and let it run, checking every 2-3 minutes and adding until it hits halfway in the hash marks on the dipstick. Test drive around the block, babying it, then park and check it again. Add if it needs it, and see how it does once you are 100% sure that the fluid level is correct.
    You can swap a quart or two of the old fluid in, if you really want to.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  1. A/c issues with transmission shift cable
    By smws6ta in forum General Grand Prix Discussion
    Last Post: 01-07-2015, 02:06 PM
  2. 4t65e hd shift issues and hard parts question.
    By Ifryrice in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-02-2014, 04:45 PM
  3. Tranny Issue help! 1st shift is slipping/sluggish.2nd and up real quick jerk shift
    By Prixness in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2014, 12:28 PM
  4. Issues with shift points
    By Frosty in forum PCM Tuning
    Last Post: 09-03-2012, 01:11 PM
  5. Installing Transgo SK4T65E shift kit - need help with valve body removal (side case)
    By Overboost in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-31-2012, 04:54 PM
