Thread: 2006 Grand Prix GT transmission shudder when cold
Results 1 to 4 of 4
  1. #1 2006 Grand Prix GT transmission shudder when cold
    Dec 2016
    Missouri
    I have a 2006 Grand Prix GT and it has 214,500 miles on it. The tranny and engine are original and the only thing I have done to the transmission is fluid changes and I also replaced the pressure control solenoid about 7k miles ago. Now, the transmission shudders between 1st and 2nd gear when up-shifting around 4k rpms and higher only if the fluid is cold. Once the transmission gets up to temperature (around 174 degrees F) the shift is smooth. It shudders every time when not up to temperature but again once its up to temp, the shudder goes away and it shifts smooth. I've used bottles of fluid to clean the clutches and insides of the tranny a couple of times, most of which only act as a band aid. Does anyone have any idea what could be causing this shudder when the tranny is cooler?
  2. #2 Re: 2006 Grand Prix GT transmission shudder when cold
    GTP Level Member
    Oct 2014
    Time for some lucus again. And cross fingers to push tranny rebuild down the road.
  3. #3 Re: 2006 Grand Prix GT transmission shudder when cold
    Dec 2016
    Missouri
    That does seem to help...and the shudder really doesnt happen at all unless I get it up into higher RPM's at a colder temp. Lucas mascs the problem, but whats the actual cause of the problem?
  4. #4 Re: 2006 Grand Prix GT transmission shudder when cold
    GTP Level Member
    Oct 2014
    I actually meant lubeguard red that's what I add. Not sure why I had lucus on the brain. May do the same thing.
  1. 2008 Grand Prix jerking, shudder at low RPM's
    By redfox89 in forum General W body
    Last Post: 07-29-2013, 09:23 PM
  2. Cold air intake for 2006 grand prix gt
    By kras20 in forum General Grand Prix Discussion
    Last Post: 07-22-2012, 07:54 AM
  3. Transmission shudder
    By geno4952 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2010, 10:10 AM
