Thread: "Rev and Clunk" Issue ? 08 5.3L GXP
Results 1 to 20 of 22
  1. #1 Re: "Rev and Clunk" Issue ? 08 5.3L GXP
    GXP Level Member
    Mar 2015
    Tomball
    This is covered in the tech tips, but as I recall it's the apply piston seal not sealing all the way and as you rev to take off the seal has more pressure behind it and it pops in and grabs and goes. My car does the same thing at times. I raised the trans pressure and that seems to help, I haven't had it happen since, but it only did it once in a while anyway. The fix from what I read was a rebuild.
    Jeff
  2. #2 Re: "Rev and Clunk" Issue ? 08 5.3L GXP
    Feb 2016
    florida
    How were you able to raise the pressure?
  3. #3 Re: "Rev and Clunk" Issue ? 08 5.3L GXP
    Mar 2014
    Tucson
    Quote Originally Posted by J57ltr View Post
    as I recall it's the apply piston seal not sealing all the way...The fix from what I read was a rebuild.
    Looks something like this:
  4. #4 Re: "Rev and Clunk" Issue ? 08 5.3L GXP
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    Jeff
    Exactly! Its the apply piston. Very common. Mine at 75k started randomly doing it. Talked with TEP and ended up ordering a trans from him. He said very very common for the delayed engagement. New trans sitting in my garage till the weather warms up to install it. You can try raising line pressure, shift kit, pcs, swap fluid, etc but in the end you need to drop the trans and fix it once it gets annoying enough. Just drive it till you get tired of it then rebuild trans.
    http://www.gmls4.com/index.php?topic=2773.0
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  1. 4T65E "Clunk" when re-engaging from a roll
    By spencertimm in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-08-2015, 09:10 PM
  2. Occasional shift "clunk" and uneasy acceleration
    By nik12937 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2011, 03:49 PM
  3. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  4. Front Driver Side "Clunk" Mystery. Any ideas?
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 05-10-2011, 03:41 PM
  5. "CLUNK" suspension noise when i step on it?
    By whitelightning in forum General Tech Discussion
    Last Post: 05-29-2010, 05:51 PM
