Thread: **HELP** 04 GTP SC shifts but wont drive
Results 1 to 20 of 113
  1. #1 Re: **HELP** 04 GTP SC shifts but wont drive
    Jan 2018
    US
    Yeah, this is the tranny I picked up from the Yard. Had these metal pieces in it..... You think the internal might be messed up?
    It seem like whoever drilled a hole in the pan to drain fluid, they also drilled right on up to hit this piece.
    What's the name of this piece? Accumulator?
    I'm about to pop open my original Tranny pan now to see what's the verdict.
    Sent from my SM-N950U using Tapatalk
  2. #2 Re: **HELP** 04 GTP SC shifts but wont drive
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Quote Originally Posted by showtastiik View Post
    Oh ok! I thought this was the one in your car! Lol
    I'd bet there's a hole in the trans pan right under here where they drill to release fluid. This is the 1-2 accumulator. If the damage is just the drill, you can swap your old one in no problem.
    I'd look into doing a shift kit while you're there and I'm a fan of sonnax lube tube retainer while the pan's off.
    If it isn't damage by the drill, I wouldn't touch this transmission unless you're doing a rebuild.
    Also, just checking, this isn't the comp-g one we told you wouldn't work is it?
  3. #3 Re: **HELP** 04 GTP SC shifts but wont drive
    Jan 2018
    US
    Quote Originally Posted by wstefan20 View Post
    Shift Kit and sonnax lube tube retainer? The drill didbt damage it though. Anything else I should look into while I have it out?
  4. #4 Re: **HELP** 04 GTP SC shifts but wont drive
    Aug 2017
    Raytown, MO
    The lube tube retainer goes on the other tubes and prevents them from pulling out. It's actually a fairly common problem. The retainer is cheap insurance. That and the shift kit should be good.
  5. #5 Re: **HELP** 04 GTP SC shifts but wont drive
    Jan 2018
    US
    Oh ok, I'll get on that than... Is it better to switch to an Aluminium Oil Pan?
  6. #6 Re: **HELP** 04 GTP SC shifts but wont drive
    PS.. there's a how to on the aluminum oil pan wink wink
  1. all wheel drive drive rain with 3.8 engine
    By fisheson in forum General Grand Prix Discussion
    Last Post: 03-11-2016, 12:13 PM
  2. GXP clunk from park to drive, drive to reverse..
    By sasquatch094 in forum General Tech Discussion
    Last Post: 02-13-2014, 04:27 PM
  3. Drive side door wont unlock
    By ffbwizard in forum General W body
    Last Post: 01-02-2014, 01:41 PM
  4. Wont upshift 2-3 but down shifts 4-3
    By bstuby in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-03-2011, 08:40 AM
  5. 1998 gtp wont drive in 4th NO SLIPPING THO
    By beno420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-21-2011, 11:23 PM
