Ok..editing isn't working so well for me.
Since you have a hoist right there.. just hook up to the engine hooks and undo the engine mount nuts and trans mount nuts.. that's 4 15mm's and you should be able to lift and wiggle. Put it on ground then unbolt engine from trans and wiggle trans off engine. Poof..there's your comp g trans that you can't really use.
WSTE: Comment in last post was for you.. so are these
