yup, just hang it in place, dont un hook a thing from the engine.
you pull the tranny out the d/s. you can leave the struts in place. undo the engine and tranny mount bolts, pop the ball joints and tie rod ends, and un clip the p/s lines and dont forget the rack shaft bolt, then drop the frame a bit and pry the shaft off. then drop the frame.
How to pull an engine: BillBoost Style bills how to a standard read. if you have the pb fix add on for chrome the pics work.
