You feel that's halfway to a rebuild? I've pulled a lot of VB/Channel plates to fix 4th gear hubs and it's quick and easy after the first. Pulling the rest of the stuff apart, replacing seals on the 1st/3rd and 2nd drums was a bit unnerving hoping you got it right w/o being able to see much at all. Then tightening up the clutch packs takes time, now test to make sure things are working. Reassembly and getting the whole sloppy mess back in properly is even more fun. IDK.. I think if he goes in just to channel/valve body he shouldn't swap in his.. but then he can't use the comp g stuff either. Maybe he can sell the comp g parts to TEP or so to get some cash off a VB/Channel plate job.
