Well fellas. After a fool day of trying to unbolt this Tranny and running errands. Still not done.... Removed the GenV Blower, cut all belts, wires and hoses and whatever that was in the way. I even removed the rear engine subframe bolts. I have 2 seat belts and a huge thick steel bar to hold the engine up....
The only thing I missed was that racket pension 11mm bolt and the 2 top tranny mount bolts below the ABS Module..
Also I couldn't find out where and how to drop the engine subframe from the front. I removed 1 nut from each side and it seemed like I'll have to lift the engine and push it back and over what is keeping the subframe from dropping..
Almost there.. Have to figure that stuff out and go back tomorrow and finish up
Sent from my SM-N950U using Tapatalk
