Thread: Driver side door won't open
Results 1 to 16 of 16
  1. #1 Driver side door won't open
    SE Level Member Paranoid's Avatar
    Apr 2012
    Cranford, NJ
    Does anyone have any tips/suggestions on removing the door panel without being able to open the door? I'm beginning to think I'll need to cut out the door handle. It's a 96 GP SE 3100.
    Let's just say this is also the last time I buy anything from Auto Zone.
    If at first you don't succeed, skydiving isn't for you.
  2. #2 Re: Driver side door won't open
    what did you replace? the lock, locking rods or handle and linkage?
    getting the inside door panel off with the door closed is not gonna happen. not with out cutting it up like you said. unless you can get a hooked rod in there and grab some linkage.
  3. #3 Re: Driver side door won't open
    Apr 2012
    Cranford, NJ
    I replaced the door handle. It took a lot of adjustment and still never worked right. I'm hoping I can just cut it out and grab onto something to get it open. It locks and unlocks fine, it just doesn't open from the inside or outside.
  4. #4 Re: Driver side door won't open
    It's an ugly thing.. Taking out the drivers seat might make it a little easier. but it's a fight.
  5. #5 Re: Driver side door won't open
    Banned
    Oct 2013
    Moorhead, MN
    I'm confused.
    You put the door back together without testing it?
    Where were your issues? And what are the issues now?
    Why was the handle replaced?
    It won't open from inside or out?
    There's a pin that probably came loose just behind your inside handle.
    I don't know about Grand Prixs, but I could get to it on my cutlass with the panel intact.
  6. #6 Re: Driver side door won't open
    Quote Originally Posted by Thompsju View Post
    I'm confused.
    No surprise
    What if he tested it and then put it together, changes nothing about his issue
    Good question on what was the issue, clearly the door won't open from either handle is the current problem.
    You just asked that
    I'd kinda expect you to post the nice parts diagram showing the likely pin/problem area. C'mon man.. get that diagram
  7. #7 Re: Driver side door won't open
    Banned
    Oct 2013
    Moorhead, MN
    You're killin me Smalls.
  8. #8 Re: Driver side door won't open
    Banned
    Oct 2013
    Moorhead, MN
  9. #9 Re: Driver side door won't open
    So you post a passenger side? Geez..
  10. #10 Re: Driver side door won't open
    Banned
    Oct 2013
    Moorhead, MN
    Rotate the pic. Lol
  11. #11 Re: Driver side door won't open
    Feb 2013
    37.295091, -121.930053
    driver side is different lay out
    Bill love how you picked his comment apart lol classic...
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  12. #12 Re: Driver side door won't open
    Banned
    Oct 2013
    Moorhead, MN
    He gets all butthurt and threatens me with an infraction over a Monty Python quote, then posts nothing but troll comments towards me thereafter.
    Ah to be a little kid again.
    Never had to deal with penis envy though. =)
  13. #13 Re: Driver side door won't open
    Apr 2012
    Cranford, NJ
    I tested it and it worked fine for about 2 weeks.
    The part of the handle that you pull to open the door broke in a way that required the entire door handle to be replaced.
    The issue now is the door won't open at all, inside or out.
    I will use the schematic (thank you) to see if I can find said pin. If so, you're my hero. However, I am unable to get the exterior door handle off without brute force.
  14. #14 Re: Driver side door won't open
    St. Louis
    Check out this thread. Maybe it will help???
    http://www.w-body.com/archive/index.php/t-14784.html
  15. #15 Re: Driver side door won't open
    Banned
    Oct 2013
    Moorhead, MN
    No surprise
    You just asked that
    Infract yourself, Asshat.
  16. #16 Re: Driver side door won't open
    antioch ill
    doesnt look like troll repsonses to me. looks like you are just asking to get banned. he agreed with you on the one part. and you dont really help yourself when you post stupid things making yourself look bad. Sorry op
  1. Replies: 3
    Last Post: 09-09-2013, 10:12 AM
  2. Driver door up, driver side unlock and power mirrors are out!!! Help
    By Dangerous313KidInAPrix in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2009, 12:12 PM
  3. Driver's side door key
    By lemmy33 in forum General Tech Discussion
    Last Post: 11-20-2009, 03:01 AM
  4. Passenger side door wont open
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 01-05-2009, 01:08 PM
